How to enable SCP on APC NMC devices in IT Expert
ITE FAQ
Answers to common questions about using EcoStruxure IT Expert
  • EcoStruxure IT Help Center
  • IT Expert
  • ITE FAQ
  • How to enable SCP on APC NMC devices in IT Expert
  • Mark as Read
  • Where is the device MAC address displayed in IT Ex...
  • How to change the name of a device in IT Expert
  • How do I activate my IT Expert license?
  • How do I add a partner to my EcoStruxure IT accoun...
  • How to change the temperature display from Celsius...
  • How to delete devices from IT Expert
  • IT Expert supported browsers
  • Can I export the IT Expert device list to CSV?
  • Are 3rd party UPS included in the UPS Score batter...
  • Can I transfer my DCE devices monitored in EcoStru...
  • Can I use the device configuration feature in IT E...
  • How can I tell if I am subscribed to IT Expert or ...
  • How often does the Gateway poll monitored devices?
  • Is the latest APC firmware available in IT Expert?
  • What happens if my IT Expert subscription expires?
  • Where can I download a DCE software update file?
  • Why are devices shown as not analyzed in the Devic...
  • Why does EcoStruxure IT show the wrong firmware ve...
  • EcoStruxure IT Expert subscription feature compari...
EcoStruxure IT Support
Request Support
Back to ITE FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2021-04-22 04:52 AM
Last Updated: Sisko JLehr Sisko ‎2024-08-09 01:19 PM
The IT Expert Device Security assessment recommends that you use SCP as the file transfer protocol on your APC NMC-based devices (NMC2 and NMC3). SCP is a secure alternative to FTP for event.txt, device configuration, and firmware update.
Note: The EcoStruxure IT Gateway does not support SCP on APC NMC1 devices.
In APC NMC firmware versions 6.8.0 and newer, SCP does not allow file transfer until the default Super User password (apc) is changed.
Configure SCP on APC SNMP devices
IT Expert Administrator users have two options to quickly configure SCP as the file transfer protocol on APC SNMP devices that use config.ini:
  • Use the Management > Device configuration option to select an APC SNMP device to use as the source to configure settings on other APC SNMP devices monitored by an EcoStruxure IT Gateway.
  • Use the Single Device Configuration option available from the Devices page. Click the APC SNMP device you want to configure, and then click the Configuration tab.
Tip: In config.ini, use the SSH entry to enable SCP.
Configure SCP in the Gateway
SCP is supported in EcoStruxure IT Gateway 1.9.0 and newer.
  • Add the correct SCP credentials for your discovered devices on the Gateway Settings > Device credentials page.
    Tip: SCP credentials for NMC devices are the SSH access credentials.
  • Discover the devices in the Gateway again. Do not delete the device before you run the discovery. Rediscovery does not affect the historical data.
See How to change device file transfer settings in the Gateway from FTP to SCP
Troubleshooting
To resolve the Invalid APC file transfer credentials error in the Gateway:
  • Click Fix SCP in the error on the Device Discovery page in the Gateway. GW_fix_SCP_360019508377.pngGW_fix_SCP_360019508377.png
  • Make sure SSH is enabled on the device.
  • Verify that the SCP credentials you added are correct. Try to successfully log into the device's web interface SSH console.
  • Make sure port 22 (the Gateway default port for SCP) is allowed on your network.
Need more NMC help? Links to product pages to find user manuals for NMCs are here.
