Video: Configure Gateway device file transfer settings
Configuration
Detailed instructions for how to configure the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Configuration
  • Video: Configure Gateway device file transfer settings
  • Mark as Read
  • File transfer status sensor on EcoStruxure IT Gate...
  • Video: Configure Gateway device file transfer sett...
  • Video: Configure device credentials in the Gateway
  • Configure Gateway device polling
  • Configure 1 minute polling in EcoStruxure IT Gatew...
  • Configure Gateway backup
  • Configure Gateway restore on Gateway 1.8+
  • Configuring Gateway backup in Gateway 1.7.0
  • Configure Gateway restore on Gateway 1.7.0
  • Configure SNMP trap ports
  • Trap receiver registration for third party devices
  • Configure SNMPv3 traps and informs in the Gateway
  • Connect PowerChute Business Edition agents (PCBE) ...
  • EcoStruxure IT Gateway logs
  • Configure Web credentials in the Gateway
EcoStruxure IT Support
Request Support
Back to Configuration
  • Mark as Read
Picard EcoStruxureIT
‎2019-01-31 04:09 AM
Last Updated: Admiral Cory_McDonald Admiral ‎2025-03-04 06:27 PM
During the initial setup of your Gateway, you specify file transfer settings to access APC SNMPv1 and SNMPv3 devices. These settings are required to retrieve and configure settings for your devices and to apply firmware updates.
To comply with stricter cybersecurity requirements across various product groups, it is recommended that you review your username/password lists and confirm that configured credentials are both active and accurate.
The file transfer methods are SCP and FTP.
It is recommended that you use SCP instead of FTP.  SCP is a secure protocol; FTP is not.
IMPORTANT: The SCP or FTP credentials on the device must match the device transfer settings on the Gateway Settings > Device credentials page.
Note: In APC NMC firmware versions 6.8.0 and newer, SCP does not allow file transfer until the default Super User password (apc) is changed.
Note: The EcoStruxure IT Gateway does not support SCP on NMC1 devices.
How to identify APC Network Management Card 1 (NMC1) devices
4404675074321_360016429054.png4404675074321_360016429054.png  Refer to your device's documentation for instructions on how to set SCP or FTP credentials.
APC NMC3 devices can be configured to limit the number of failed login attempts.
If the number of device file transfer credentials you provide in the Gateway exceeds the number of failed login attempts allowed on the NMC3 device, the device might be locked.
More...
Add or modify device configuration settings in the Gateway
  1. Log in to the Gateway, and go to Settings > Device credentials.
  2. In the Device Configuration and Firmware Update section, click New file transfer credentials to create additional settings, or click the tiles for the existing settings to modify them.
Rediscover devices
IMPORTANT: After you modify the device configuration settings in the Gateway, you must run a discovery again to update the devices that need to use the new credentials.
You do not have to delete the devices.
  1. Go to Discover devices.
  2. Click Configure Credentials to select specific device file transfer credentials to use in a device discovery.
    More...
Comments
cloudassistant
cloudassistant
Cadet
  • Mark as Read
‎2025-07-18 04:09 AM
Should you use an account other than the apc account for SCP and FTP?  If so, what user type does it need to be?  i.e. Admin, Device etc...
It feels wrong to be using the main account for SCP and FTP.
Thanks in advance.
JLehr
Sisko JLehr Sisko
Sisko
  • Mark as Read
‎2025-10-03 02:31 PM
Hi @cloudassistant
That account name is used only as an example here.
Thanks for asking, though. I can see where it might be confusing.
