Can I change the default subnet for the Gateway appliance private LAN?
Gateway FAQ
Answers to common questions about the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Gateway FAQ
  • Can I change the default subnet for the Gateway appliance private LAN?
  • Mark as Read
  • How to identify APC Network Management Card 1 (NMC...
  • Where is the registration code to connect the Gate...
  • Where can I find the Gateway discovery log?
  • Uniflair device discovery for EcoStruxure IT Gatew...
  • Ripple20 vulnerabilities in the Treck TCP/IP stack
  • Modbus gateways
  • How to update the Gateway device library
  • How to reset the Gateway admin password in Gateway...
  • How to request device support for EcoStruxure IT G...
  • How to find the EcoStruxure IT Gateway serial numb...
  • How to discover a Uniflair cooling device - Gatewa...
  • How to discover NetBotz appliances in Gateway
  • How to connect to EcoStruxure IT using Data Center...
  • How to change device file transfer settings in the...
  • How can I see if my device is currently supported?
  • Gateway support for multiple network adapters
  • Gateway auto-update in IT Expert
  • EcoStruxure IT Gateway date and time settings
  • Do I need a dedicated server for EcoStruxure IT Ga...
  • Connecting a Smart-UPS to the Gateway with serial ...
  • Can the Gateway discover SmartConnect UPSs?
  • Can I change the default subnet for the Gateway ap...
  • Can EcoStruxure IT Gateway discover devices on the...
  • Modbus gateways
EcoStruxure IT Support
Request Support
Back to Gateway FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2019-10-11 04:40 AM
Gateway appliance version 1.10 and newer
Yes. You can change the default settings from the Gateway appliance private network user interface.
See EcoStruxure IT Gateway appliance installation and setup - version 1.10 and newer
Gateway appliance version 1.9 and older
No. The Gateway appliance private LAN subnet must be 198.168.x.x. The IP address for the Gateway appliance is 192.168.0.1 by default.
You must contact support to change the Gateway appliance private LAN subnet to anything other than 192.168.x.x.
DO NOT USE WEBMIN TO CHANGE THE SUBNET FOR THE GATEWAY APPLIANCE PRIVATE LAN
If you connect to Webmin on the private LAN and change the Gateway appliance IP address to a subnet other than 192.168.x.x, you will be locked out of Webmin, and completely locked out of the Gateway appliance. You must then call support to reset your appliance.
