Do I need a dedicated server for EcoStruxure IT Gateway?
Gateway FAQ
Answers to common questions about the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Gateway FAQ
  • Do I need a dedicated server for EcoStruxure IT Gateway?
  • Mark as Read
  • How to identify APC Network Management Card 1 (NMC...
  • Where is the registration code to connect the Gate...
  • Where can I find the Gateway discovery log?
  • Uniflair device discovery for EcoStruxure IT Gatew...
  • Ripple20 vulnerabilities in the Treck TCP/IP stack
  • Modbus gateways
  • How to update the Gateway device library
  • How to reset the Gateway admin password in Gateway...
  • How to request device support for EcoStruxure IT G...
  • How to find the EcoStruxure IT Gateway serial numb...
  • How to discover a Uniflair cooling device - Gatewa...
  • How to discover NetBotz appliances in Gateway
  • How to connect to EcoStruxure IT using Data Center...
  • How to change device file transfer settings in the...
  • How can I see if my device is currently supported?
  • Gateway support for multiple network adapters
  • Gateway auto-update in IT Expert
  • EcoStruxure IT Gateway date and time settings
  • Do I need a dedicated server for EcoStruxure IT Ga...
  • Connecting a Smart-UPS to the Gateway with serial ...
  • Can the Gateway discover SmartConnect UPSs?
  • Can I change the default subnet for the Gateway ap...
  • Can EcoStruxure IT Gateway discover devices on the...
  • Modbus gateways
EcoStruxure IT Support
Request Support
Back to Gateway FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2022-08-18 01:37 AM
It is recommended that you install EcoStruxure IT Gateway on a dedicated VM or hardware server.
If you must install the Gateway on a server with shared resources, make sure there are enough free resources for your Gateway installation. The required CPU and memory depends on the number of monitored devices and the protocol.
See
System requirements for EcoStruxure IT Gateway
EcoStruxure IT Gateway security considerations
Comments
Wavetixio
Wavetixio
Cadet
  • Mark as Read
‎2024-05-09 07:40 AM
So, about needing a dedicated server for EcoStruxure IT Gateway, here's my take: while it's recommended for optimal performance, you can still make it work on a shared server if you manage your resources wisely.
