How to discover a Uniflair cooling device - Gateway 1.7 and older
Gateway FAQ
Answers to common questions about the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Gateway FAQ
  • How to discover a Uniflair cooling device - Gateway 1.7 and older
  • Mark as Read
  • How to identify APC Network Management Card 1 (NMC...
  • Where is the registration code to connect the Gate...
  • Where can I find the Gateway discovery log?
  • Uniflair device discovery for EcoStruxure IT Gatew...
  • Ripple20 vulnerabilities in the Treck TCP/IP stack
  • Modbus gateways
  • How to update the Gateway device library
  • How to reset the Gateway admin password in Gateway...
  • How to request device support for EcoStruxure IT G...
  • How to find the EcoStruxure IT Gateway serial numb...
  • How to discover a Uniflair cooling device - Gatewa...
  • How to discover NetBotz appliances in Gateway
  • How to connect to EcoStruxure IT using Data Center...
  • How to change device file transfer settings in the...
  • How can I see if my device is currently supported?
  • Gateway support for multiple network adapters
  • Gateway auto-update in IT Expert
  • EcoStruxure IT Gateway date and time settings
  • Do I need a dedicated server for EcoStruxure IT Ga...
  • Connecting a Smart-UPS to the Gateway with serial ...
  • Can the Gateway discover SmartConnect UPSs?
  • Can I change the default subnet for the Gateway ap...
  • Can EcoStruxure IT Gateway discover devices on the...
  • Modbus gateways
EcoStruxure IT Support
Request Support
Back to Gateway FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2019-01-30 08:59 PM
This article pertains to Gateway versions 1.7.0 and older. See this article for versions 1.8.1 and later.
Log in to your EcoStruxure IT Gateway.
Click the menu icon, then Discovery.
Click Create Discovery.
In Device Discovery, select the Advanced option, and select the device family that matches your device:
Device type: Crac
Device vendor: Uniflair
Device family: Aquascroll, Ug40mp40_imperial, Ug40mp40_metric
Enter the IP address of the device, and select SNMPv1 or SNMPv3.
  • Specify the IP address, and select SNMPv1 or SNMPv3.
    For SNMPv1, specify the Read community name (public is default), the Write community name (private is default), and the port, (161 is default).
  • For SNMPv3, specify the Username, Authentication type (MD5 or SHA), Authentication password, Encryption type (DES, DES3, AES128, AES192, AES256), Encryption password, and Port (161 is default).
Run the discovery.
Note: Advanced discovery is necessary for only the specific devices listed in this option.
