How to discover NetBotz appliances in Gateway
Gateway FAQ
Answers to common questions about the EcoStruxure IT Gateway
Send InviteCancel
To discover NetBotz appliances in EcoStruxure IT Gateway, provide the appropriate device credentials on the Device configuration page in the Gateway setup wizard.
Otherwise, go to Settings > Advanced > Device credentials and click New device credentials.
The device credential type you choose depends on the model of the NetBotz appliance.
NetBotz 200, 250, 750/755
Choose SNMPv1 or SNMPv3 to create device credential settings for NetBotz 200, 250, and 750/755 appliances.
Enter the correct community strings or SNMPv3 passphrases.
Note: If you add sensors to the NetBotz 250 or NetBotz 750/755 after you discover it, you must manually rediscover the device to see those sensors in the Gateway. You do not have to delete the NetBotz device before you run a new discovery.
Netbotz 355, 455, 450, 570
Choose NetBotz to create device credential settings for NetBotz 355, 455, 450, and 570 appliances.
Enter the administrative username and password.
Note: Support for unsafe ciphers was removed as part of a security update in EcoStruxure IT Gateway version 1.8.0.
NetBotz 4.x devices must now support 2048 bit certificates. Self-signed automatically generated SSL certificates use 2048-bit encryption as of NetBotz version 4.5.4.
