Connecting a Smart-UPS to the Gateway with serial Modbus
Gateway FAQ
Answers to common questions about the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Gateway FAQ
  • Connecting a Smart-UPS to the Gateway with serial Modbus
  • Mark as Read
  • How to identify APC Network Management Card 1 (NMC...
  • Where is the registration code to connect the Gate...
  • Where can I find the Gateway discovery log?
  • Uniflair device discovery for EcoStruxure IT Gatew...
  • Ripple20 vulnerabilities in the Treck TCP/IP stack
  • Modbus gateways
  • How to update the Gateway device library
  • How to reset the Gateway admin password in Gateway...
  • How to request device support for EcoStruxure IT G...
  • How to find the EcoStruxure IT Gateway serial numb...
  • How to discover a Uniflair cooling device - Gatewa...
  • How to discover NetBotz appliances in Gateway
  • How to connect to EcoStruxure IT using Data Center...
  • How to change device file transfer settings in the...
  • How can I see if my device is currently supported?
  • Gateway support for multiple network adapters
  • Gateway auto-update in IT Expert
  • EcoStruxure IT Gateway date and time settings
  • Do I need a dedicated server for EcoStruxure IT Ga...
  • Connecting a Smart-UPS to the Gateway with serial ...
  • Can the Gateway discover SmartConnect UPSs?
  • Can I change the default subnet for the Gateway ap...
  • Can EcoStruxure IT Gateway discover devices on the...
  • Modbus gateways
EcoStruxure IT Support
Request Support
Back to Gateway FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2020-05-19 10:46 PM
You can connect Smart-UPS models starting with SMT, SMTL, SRT, and SURT to EcoStruxure IT Gateway with serial Modbus, also called Modbus RTU.
  1. Enable Modbus on the UPS.  From the display on the front of the UPS, first enable the advanced menu, then enable Modbus.
  2. Connect the serial cable between the UPS and the Gateway computer.
    Use an APC cable, part number 940-0625 or 940-1525. More info on which cable you need
    Connect the RJ45 port labeled Serial on the UPS to a DB9 connector on the computer running the Gateway.
    If the computer does not have a DB9 connector, you will need a USB to RS232 converter as well. These converters are inexpensive and available from plugable.com and cablematters.com.  You might also need to install the driver for the cable.
    The driver is pre-installed on many Linux systems. On Windows, download and install the driver for the converter. Check the documentation for the cable you are using. The cables from plugable.com and cablematters.com probably use this driver: http://www.prolific.com.tw/US/ShowProduct.aspx?p_id=225&pcid=41.
  3. Discover the device in the Gateway. Go to Discover devices and then click Discovering a Modbus device?
  4. Use these parameters:
    • Type: UPS; Device Vendor: APC; Device family: Smart-UPS; Server address: 1
    • Serial
    • Port
      On Windows, go to Device Manager and look under Ports (COM & LPT) for the port number.  If you're using the driver described above, it will show as Prolific USB-to_serial Comm Port followed by the port number.
    • Baud Rate: 9600; Data Bits: 8; Parity: None; Stop Bits: 1; Flow Control: None
    GW_discover_Smart-UPS_serial_Modbus_360008889677.pngGW_discover_Smart-UPS_serial_Modbus_360008889677.png
See also
Modbus Implementation in APC Smart-UPS
Smart-UPS Communications
APC Forum discussion
100% helpful (1/1)
