Gateway auto-update in IT Expert
Gateway FAQ
Answers to common questions about the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Gateway FAQ
  • Gateway auto-update in IT Expert
  • Mark as Read
  • How to identify APC Network Management Card 1 (NMC...
  • Where is the registration code to connect the Gate...
  • Where can I find the Gateway discovery log?
  • Uniflair device discovery for EcoStruxure IT Gatew...
  • Ripple20 vulnerabilities in the Treck TCP/IP stack
  • Modbus gateways
  • How to update the Gateway device library
  • How to reset the Gateway admin password in Gateway...
  • How to request device support for EcoStruxure IT G...
  • How to find the EcoStruxure IT Gateway serial numb...
  • How to discover a Uniflair cooling device - Gatewa...
  • How to discover NetBotz appliances in Gateway
  • How to connect to EcoStruxure IT using Data Center...
  • How to change device file transfer settings in the...
  • How can I see if my device is currently supported?
  • Gateway support for multiple network adapters
  • EcoStruxure IT Gateway date and time settings
  • Do I need a dedicated server for EcoStruxure IT Ga...
  • Connecting a Smart-UPS to the Gateway with serial ...
  • Can the Gateway discover SmartConnect UPSs?
  • Can I change the default subnet for the Gateway ap...
  • Can EcoStruxure IT Gateway discover devices on the...
  • Modbus gateways
EcoStruxure IT Support
Request Support
Back to Gateway FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2019-01-29 05:30 AM
Last Updated: Sisko JLehr Sisko ‎2025-05-22 02:00 PM
When you enable auto-update on a Gateway connected to IT Expert, you allow Schneider Electric to automatically update it when a new software version is available.
Gateway auto-updates are rolled out incrementally after the release is announced.
Log in to EcoStruxure IT.
Select Administration > Gateways and Enable auto-update.
You can also double click a Gateway tile and check the box to enable auto-update, or uncheck the box to disable it.
New Gateway versions can be installed with minimal downtime, and are deployed in parallel with the currently running instance. You can actively monitor your devices while data migration and new version deployment completes.
To minimize downtime, the previous Gateway version continues to communicate sensor data and alarms to the cloud while the new Gateway version is installed. Some features are disabled during this process, such as device discovery and system configuration.
Once the new Gateway version is installed, the Gateway automatically restarts. Data collection and reporting to the cloud is interrupted during this time.
At the next polling cycle, data collection will resume and data will be pushed to the cloud.
If the new Gateway version fails to install, the update process is designed to roll back to the previous version.
Note: The EcoStruxure IT cloud initiates temporary scripts that run to manage the auto-update process for EcoStruxure IT Gateway installed on Windows and Linux. Scanning tools may report events for these scripts.
Device library auto-update in IT Expert
The Gateway software update is always presented first. If a device library update is also available, it will be presented after the Gateway software is updated.
Device library updates are released frequently, independent from Gateway software releases.
Gateways configured for auto-update require an Administrator user to manually initiate the device library update when a new version of the device library is available independent of a Gateway software release.
See How to update the Gateway device library
Comments
LarryK
Lt. Commander LarryK
Lt. Commander
  • Mark as Read
‎2025-01-28 11:55 AM
I have always allowed auto-update on my client's sites.
And yet, I must access the specific ESIT instance, access Administration, click on the update, and confirm it before the update takes place.
Please explain how any of this is "auto"?
JLehr
Sisko JLehr Sisko
Sisko
  • Mark as Read
‎2025-05-22 09:27 AM
LarryK
Lt. Commander
  • Mark as Read
‎2025-06-05 09:18 AM
@JLehr - what is the expected "delay time" I should afford to this sequence?  In other words, how long should I consider waiting before I continue manually doing what I do?
JLehr
Sisko JLehr Sisko
Sisko
  • Mark as Read
‎2025-06-06 05:52 AM
Hi @LarryK,
New Gateway versions are rolled out in phases. It can take 30 days or more for all the Gateways monitored by IT Expert to be auto-updated. You can initiate the update manually from IT Expert any time after the new version is available if you prefer not to wait.
