Gateway support for multiple network adapters
Gateway FAQ
Answers to common questions about the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Gateway FAQ
  • Gateway support for multiple network adapters
  • Mark as Read
  • How to identify APC Network Management Card 1 (NMC...
  • Where is the registration code to connect the Gate...
  • Where can I find the Gateway discovery log?
  • Uniflair device discovery for EcoStruxure IT Gatew...
  • Ripple20 vulnerabilities in the Treck TCP/IP stack
  • Modbus gateways
  • How to update the Gateway device library
  • How to reset the Gateway admin password in Gateway...
  • How to request device support for EcoStruxure IT G...
  • How to find the EcoStruxure IT Gateway serial numb...
  • How to discover a Uniflair cooling device - Gatewa...
  • How to discover NetBotz appliances in Gateway
  • How to connect to EcoStruxure IT using Data Center...
  • How to change device file transfer settings in the...
  • How can I see if my device is currently supported?
  • Gateway auto-update in IT Expert
  • EcoStruxure IT Gateway date and time settings
  • Do I need a dedicated server for EcoStruxure IT Ga...
  • Connecting a Smart-UPS to the Gateway with serial ...
  • Can the Gateway discover SmartConnect UPSs?
  • Can I change the default subnet for the Gateway ap...
  • Can EcoStruxure IT Gateway discover devices on the...
  • Modbus gateways
EcoStruxure IT Support
Request Support
Back to Gateway FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2019-01-31 03:40 AM
When the EcoStruxure IT Gateway server starts, it detects all the available network adapters defined in the operating system and uses all of them to connect to the devices. When you are logged into the Gateway, the IP addresses the Gateway is communicating with are displayed on the Settings > About page.
You can use the Gateway user interface on the public network as a proxy to the user interfaces of the monitored devices on the private network.
Note: The Gateway user interface does not limit how many network adapters it connects to. One public and one private network is typical.
To connect to a device user interface:
  1. In the Gateway, go to Devices. Click a device and then the Details tab.
  2. Click the IP address link to launch to the device.
Also see EcoStruxure IT Gateway in a Secure Network Architecture
