How to reset the Gateway admin password in Gateway version 1.8.0 and newer
Gateway FAQ
Answers to common questions about the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Gateway FAQ
  • How to reset the Gateway admin password in Gateway version 1.8.0 and newer
  • Mark as Read
  • How to identify APC Network Management Card 1 (NMC...
  • Where is the registration code to connect the Gate...
  • Where can I find the Gateway discovery log?
  • Uniflair device discovery for EcoStruxure IT Gatew...
  • Ripple20 vulnerabilities in the Treck TCP/IP stack
  • Modbus gateways
  • How to update the Gateway device library
  • How to reset the Gateway admin password in Gateway...
  • How to request device support for EcoStruxure IT G...
  • How to find the EcoStruxure IT Gateway serial numb...
  • How to discover a Uniflair cooling device - Gatewa...
  • How to discover NetBotz appliances in Gateway
  • How to connect to EcoStruxure IT using Data Center...
  • How to change device file transfer settings in the...
  • How can I see if my device is currently supported?
  • Gateway support for multiple network adapters
  • Gateway auto-update in IT Expert
  • EcoStruxure IT Gateway date and time settings
  • Do I need a dedicated server for EcoStruxure IT Ga...
  • Connecting a Smart-UPS to the Gateway with serial ...
  • Can the Gateway discover SmartConnect UPSs?
  • Can I change the default subnet for the Gateway ap...
  • Can EcoStruxure IT Gateway discover devices on the...
  • Modbus gateways
EcoStruxure IT Support
Request Support
Back to Gateway FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2020-03-27 06:22 AM
Last Updated: Sisko JLehr Sisko ‎2024-11-12 05:23 AM
Starting with EcoStruxure IT Gateway 1.8.0, you reset the admin user’s password using a dedicated command. Resetting the admin user password is no longer associated with the restore, does not have a default value, and does not require a manual Gateway service restart afterwards.
Instructions on how to reset the Gateway admin password for Gateway versions prior to 1.8.0 are here.
Note: In the examples below, replace <version number> with the Gateway version number as it is shown in the installation directory.
Windows
You must be an Administrator or run the command prompt as administrator.
      1. Open a command window. Right-click the command prompt icon and click Run as administrator.
      2. Navigate to C:\Program Files\EcoStruxure IT Gateway\<version number>\bin.
        Type the command cd  C:\Program Files\EcoStruxure IT Gateway\<version number>\bin To see the contents of the directory, type the command dir
      3. Type the command reset-password.bat
      4. Set the new password when prompted.
Linux
      1. Navigate to /opt/EcoStruxureITGateway/<version number>/bin.
        Type the command cd /opt/EcoStruxureITGateway/<version number>/bin
      2. Type the command ./reset-password.sh
      3. Set the new password when prompted.
Note: If the admin user was previously deleted, it is recreated on password reset.
Comments
wasabi
Lieutenant JG wasabi Lieutenant JG
Lieutenant JG
  • Mark as Read
‎2024-03-26 03:32 AM
Hi, I have a question around resetting the admin password if the Gateway is installed on the NUC appliance with the Linux Centos ISO image which is headless version. if its no longer supported how can we obtain the root password to login via the command line to execute this password reset ?
