How to reset the Gateway admin password in Gateway 1.7.0 and older
Gateway FAQ
Answers to common questions about the EcoStruxure IT Gateway
  • EcoStruxure IT Help Center
  • Gateway
  • Gateway FAQ
  • How to reset the Gateway admin password in Gateway 1.7.0 and older
  • Mark as Read
  • How to identify APC Network Management Card 1 (NMC...
  • Where is the registration code to connect the Gate...
  • Where can I find the Gateway discovery log?
  • Uniflair device discovery for EcoStruxure IT Gatew...
  • Ripple20 vulnerabilities in the Treck TCP/IP stack
  • Modbus gateways
  • How to update the Gateway device library
  • How to reset the Gateway admin password in Gateway...
  • How to request device support for EcoStruxure IT G...
  • How to find the EcoStruxure IT Gateway serial numb...
  • How to discover a Uniflair cooling device - Gatewa...
  • How to discover NetBotz appliances in Gateway
  • How to connect to EcoStruxure IT using Data Center...
  • How to change device file transfer settings in the...
  • How can I see if my device is currently supported?
  • Gateway support for multiple network adapters
  • Gateway auto-update in IT Expert
  • EcoStruxure IT Gateway date and time settings
  • Do I need a dedicated server for EcoStruxure IT Ga...
  • Connecting a Smart-UPS to the Gateway with serial ...
  • Can the Gateway discover SmartConnect UPSs?
  • Can I change the default subnet for the Gateway ap...
  • Can EcoStruxure IT Gateway discover devices on the...
  • Modbus gateways
EcoStruxure IT Support
Request Support
Back to Gateway FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2018-11-14 01:12 PM
Last Updated: Sisko JLehr Sisko ‎2024-11-12 05:27 AM
Instructions on how to reset the Gateway admin password for Gateway 1.8 and newer are here.
The password for the admin account will be reset to admin. Users are required to change their password at first login.
Note: In the examples below, replace X.X.X with your Gateway version number.
Windows
You must be an Administrator or run the command prompt as administrator.
  1. Open a command window. Right-click the command prompt icon and click Run as administrator. Gateway_run_as_admin_360012170533.pngGateway_run_as_admin_360012170533.png
  2. Navigate to C:\Program Files\EcoStruxure IT Gateway\X.X.X\restore.
    Type the command cd  C:\Program Files\EcoStruxure IT Gateway\X.X.X\restore
  3. Type the command restore.bat password-reset
  4. Go to Control Panel > Administrative Tools > Services.
  5. Restart the "EcoStruxureITGateway Server - X.X.X.X" service.
Linux
  1. Open a command window and type cd /opt/ExoStruxureITGateway/X.X.X/restore
  2. Type ./restore.sh password-reset
  3. Restart the EcoStruxure IT Gateway Server.  Type systemctl restart EcoStruxureITGateway-X.X.X.service
    The systemctl command can be run from any directory by sudo users.
