How can I see if my device is currently supported?
Gateway FAQ
Answers to common questions about the EcoStruxure IT Gateway
Select a Country
  • EcoStruxure IT Help Center
  • Gateway
  • Gateway FAQ
  • How can I see if my device is currently supported?
  • Mark as Read
  • How to identify APC Network Management Card 1 (NMC...
  • Can I use EcoStruxure IT Gateway and Data Center E...
  • Where is the registration code to connect the Gate...
  • Where can I find the Gateway discovery log?
  • Uniflair device discovery for EcoStruxure IT Gatew...
  • Ripple20 vulnerabilities in the Treck TCP/IP stack
  • Modbus gateways
  • How to update the Gateway device library
  • How to reset the Gateway admin password
  • How to request device support for EcoStruxure IT G...
  • How to find the EcoStruxure IT Gateway serial numb...
  • How to discover a Uniflair cooling device - Gatewa...
  • How to discover NetBotz appliances in Gateway
  • How to connect to EcoStruxure IT using Data Center...
  • How to change device file transfer settings in the...
  • Gateway support for multiple network adapters
  • Gateway auto-update in IT Expert
  • EcoStruxure IT Gateway date and time settings
  • Do I need a dedicated server for EcoStruxure IT Ga...
  • Connecting a Smart-UPS to the Gateway with serial ...
  • Can the Gateway discover SmartConnect UPSs?
  • Can I change the default subnet for the Gateway ap...
  • Can EcoStruxure IT Gateway discover devices on the...
  • Modbus gateways
EcoStruxure IT Support
Request Support
Back to Gateway FAQ
  • Mark as Read
EcoStruxureIT
‎2019-04-01 08:25 AM
Last Updated: JLehr Champion ‎2024-04-03 04:21 AM
Schneider Electric devices
Schneider Electric branded (including APC and Uniflair) UPSs, PDUs, and cooling devices are all supported and should able to be monitored. Other Schneider Electric devices, such as power meters, branch circuit monitors, and breakers, are most likely already supported; if they are not, please submit a request and they will be added quickly.
Third party devices
The ability to monitor many third party devices is also already available. The details about which devices have been added are in this report.
Also see the EcoStruxure IT Gateway device library release notes
Support for a third party device is done based on the information in an SNMP MIB or Modbus register map. This often allows many different models within that family to communicate with EcoStruxure IT even though they are not explicitly documented in the report. They are not documented because a list of devices supported by an SNMP MIB map isn't maintained by the manufacturers.
Conversely, a model could appear on the report, but IT Expert is unable to monitor a specific device of the same model. This is often because the device uses a different network communication card or has a different version of firmware.
The only way to know with 100% certainty that your third party device is supported is to install the EcoStruxure IT Gateway, discover the device, and look at the sensors.
If that is not feasible, you can generate an SNMP walk of the device and then send it to us.
Integrating Third-party Devices into Schneider Electric’s DCIM Monitoring Tools: Data Center Expert ...
