  • Mark all as New
  • Mark all as Read
  • Float this item to the top
  • Invite a Friend
  • Threaded format
  • Linear Format
  • Sort by Topic Start Date
The message you are trying to access is permanently deleted.
wiser-logo
Conversation by Products
Explore our products forum and get answers to your questions:
Temperature control
Temperature control
Safety
Safety
Security
Security
Apps
Apps
Gateways
Gateways
Lighting
Lighting
Energy management
Energy management
Shutter and blind
Shutter and blind
Voice control
Voice control
Top Labels
Top Labels
  • Alphabetical
  • Temperature Control 89
  • Apps 68
  • About Wiser 59
  • Energy management 29
  • Gateways and Hubs 23
  • Gateways 19
  • Bugs 18
  • Lighting 14
  • Knowledge questions 14
  • Connectivity Devices 13
  • Mobile Applications 12
  • Shutter and Blind 12
  • Safety 11
  • Energy devices 11
  • Usability issues 9
  • Voice Control 8
  • Security 8
  • Announcements and Release Notes 7
  • OTHERS 7
  • User Testimonials 6
  • Ideas of improvements 5
  • Others & accessories 1
  • Did you know 1
  • Communicating Actuators and Energy Valves 1
  • Thermostats 1
  • Visual feedback 1
  • Previous
  • 1 of 2
  • Next
David_SE
Captain David_SE Captain
149
Alfred_SE
24
Maude.wiser.
22
Thumbnail of Wiser
Wiser
9
Thumbnail of Wiser for KNX : logic controller
6
Thumbnail of PowerLogic™ PowerTag
2
  • All
  • Solved
  • Unsolved
  • Unanswered
Informational
David_SE
/html/rank_icons/Captain.png David_SE /html/rank_icons/SE-Employee.png
Wiser Home app new version - v7.3.0 & Wiser Home Hub 2nd Gen new FW ve...
Dear Wiser user, A new Wiser Home app version v7.3.0 and a new Wiser Home Hub 2nd Gen FW version 4.42.23 will be deployed that week. In addition to bug fixes and enhancements, this release co...
Schneider Electric Wiser icon_circle Schneider Electric Wiser Forum
1042 1 5
Latest Reply: Zigzag5885
Alfred_SE
Alfred_SE /html/rank_icons/Retired-User.png
Welcome to the Schneider Electric Wiser Community!
Dear Wiser user, Interact with other #Wiser users while staying up to date on the newest news, features, and customer stories. Have a #Wiser Life! A whole new #Wiser environment for you to get to...
4550 9 3
Latest Reply: StewartT
Lobman
Lobman
Issue with wiser not reaching set point.
We have a particular room in our house where the wiser hub doesn't ever seem to manage to get the room to it's set point. It's the coldest room in the house. We tend to set the temperature to 18.5C. ...
131 0 2
Latest Reply: LaxieD09
Houseyhousey
Houseyhousey
Working stroke of Wiser Thermostatic Radiator valve
What is the actual working stroke of the Wiser radiator valve, as mine only seems to move about 1.5mm, but the pin on the valve moves about 3mm?
35 0 2
Latest Reply: Houseyhousey
DaveP
/html/rank_icons/Ensign.png DaveP
Wiser Thermostatic Radiator Head Not Fully Opening
If I twist and hold the head clockwise the red led lights up and the actuator fully retracts leaving a small gap to the TRV pin, so I know it can physically fully open it. I then twist it anticlockwise...
36 1 2
astephon88
astephon88
Erratic Smart Radiator Thermostat Temp Readings
I've recently picked up a Gen1 HubR, a room thermostat and several radiator thermostats. The control of the room with the room thermostat has been stellar; however, the rooms with only radiator thermos...
95 0 3
Latest Reply: Polarismd
PaoloF
PaoloF
Looking for a working APK for legacy Wiser system (EER21000 + EER53000...
Hello,I recently bought an apartment equipped with an older Wiser heating control system composed by: 1 x Wiser Controller EER21000 5 x Wiser Radiator Thermostats EER53000 1 x Wiser Smart Plug EE...
15 0 0
2025-11-30
sberry
sberry
TRV plunger not retracting enough after battery change
When installed from new, my radiator TRV worked fine. However, when it came to changing the batteries, the TRV wouldn't open enough to allow any heat into the radiator. I replaced the batteries and c...
309 1 2
Latest Reply: Steven4
FredFive
FredFive
No more HA connection with my Wiser Home Hub 2nd Gen
Hello. For the past month, my Home Assistant server has consistently failed to establish a connection with my Wiser Home Hub 2nd Gen. The following error repeatedly appears in the logs: "certificate v...
105 0 1
Latest Reply: David_SE
JR5
JR5
Wiser hub v2 connection error
I have followed hub wifi tips here, have latest iPhone and wiser firmware have fixed 2.4ghz wifi channel, reserved ip address for the hub in my router but still have connection errors every few days. ...
189 0 3
Bazza1878
Bazza1878
Wiser hub
Hi all, I’ve just installed the wiser hub and app and set up a heating schedule, my question is why does my boiler continue to fire past the scheduled time? i.e. I have set the temp at 20 degrees from ...
124 0 1
Kernow_Yardie
Kernow_Yardie
Eco Mode Question
Please look at image for message as get error saying message isn’t allowed.  
103 0 1
Pyrotech
Pyrotech
Noisy smart thermostat heads
I have installed a wiser kit 1 to our 3 storey town house due to the temperature difference between floors. The system works well in conjunction with wet underfloor heating on the ground floor. However...
162 0 3
  • « Previous
    • 1
    • 2
    • 3
    • 28
  • Next »
