Working stroke of Wiser Thermostatic Radiator valve
  • Working stroke of Wiser Thermostatic Radiator valve
David_SE
Captain David_SE Captain
149
Alfred_SE
24
Maude.wiser.
22
Wiser
Houseyhousey
Houseyhousey
Cadet
Posted: ‎2025-11-30 01:53 PM
57
What is the actual working stroke of the Wiser radiator valve, as mine only seems to move about 1.5mm, but the pin on the valve moves about 3mm?
  • Temperature Control
Polarismd
Polarismd
Cadet
Posted: ‎2025-12-03 01:40 AM
You might need to recalibrate. Sorry if you know how to do this already but..... ensure the thermostat is fully secured on the valve, take out the batteries (wait a few seconds) then reconnect them. The lights will flash for a few seconds and then it will fully open the valve (only red light will appear). Once that has happened turn the thermostat to off, blue light will appear. Thermostat will recalibrate.
Houseyhousey
Houseyhousey
Cadet
Posted: ‎2025-12-03 11:36 AM
I have watched the your video and recalibrated the WISER head numerous times, and still when there is a demand for heat the head only opens a fraction, not enough for the radiator to get really hot and heat the room. If I remove the head the radiator gets really hot, and the valve pin moves freely.
I assume the head calibrates itself by sensing the increase in motor current when it touches the valve pin, then senses fully closed when the current increases again?
Is there no way of getting the WISER head to fully retract when there's a demand for heat, reading the forum I'm not the only one having this problem ?
