  • Mark all as New
  • Mark all as Read
  • Float this item to the top
  • Invite a Friend
  • Threaded format
  • Linear Format
  • Sort by Topic Start Date
The message you are trying to access is permanently deleted.
wiser-logo
Conversation by Products
Explore our products forum and get answers to your questions:
Temperature control
Temperature control
Safety
Safety
Security
Security
Apps
Apps
Gateways
Gateways
Lighting
Lighting
Energy management
Energy management
Shutter and blind
Shutter and blind
Voice control
Voice control
Top Labels
Top Labels
  • Alphabetical
  • Temperature Control 86
  • Apps 68
  • About Wiser 59
  • Energy management 29
  • Gateways and Hubs 23
  • Gateways 19
  • Bugs 18
  • Lighting 14
  • Connectivity Devices 13
  • Knowledge questions 13
  • Shutter and Blind 12
  • Mobile Applications 11
  • Safety 11
  • Energy devices 11
  • Usability issues 9
  • Voice Control 8
  • Security 8
  • Announcements and Release Notes 7
  • OTHERS 7
  • User Testimonials 6
  • Ideas of improvements 5
  • Others & accessories 1
  • Did you know 1
  • Communicating Actuators and Energy Valves 1
  • Thermostats 1
  • Visual feedback 1
  • Previous
  • 1 of 2
  • Next
David_SE
Captain David_SE Captain
144
Alfred_SE
24
Maude.wiser.
22
Thumbnail of Wiser
Wiser
8
Thumbnail of Wiser for KNX : logic controller
6
Thumbnail of PowerLogic™ PowerTag
2
  • All
  • Solved
  • Unsolved
  • Unanswered
Informational
David_SE
/html/rank_icons/Captain.png David_SE /html/rank_icons/SE-Employee.png
Wiser Home app new version - v7.3.0 & Wiser Home Hub 2nd Gen new FW ve...
Dear Wiser user, A new Wiser Home app version v7.3.0 and a new Wiser Home Hub 2nd Gen FW version 4.42.23 will be deployed that week. In addition to bug fixes and enhancements, this release co...
Schneider Electric Wiser icon_circle Schneider Electric Wiser Forum
851 1 4
Latest Reply: bobtherock
Alfred_SE
Alfred_SE /html/rank_icons/Retired-User.png
Welcome to the Schneider Electric Wiser Community!
Dear Wiser user, Interact with other #Wiser users while staying up to date on the newest news, features, and customer stories. Have a #Wiser Life! A whole new #Wiser environment for you to get to...
4415 9 3
Latest Reply: StewartT
Informational
David_SE
851 1 4
Julsp
/html/rank_icons/Ensign.png Julsp
Automatisme Prise connectée / Capteur de température
Bonjour, J’ai besoin d’utiliser un radiateur électrique sur pied ou roulette dans une pièce. Ce radiateur n’aura pas de fil pilote. Sa puissance sera de quelques centaines de W. Je dispose d’un c...
55 0 1
Latest Reply: David_SE
kris2
kris2
wiser app verify email
Hi, i am not receiving an verify email from the app? and its not in my junk folder. so can not login
46 0 1
Niall1
Niall1
Wiser hub 2 disconnected from internet and lost all programming except...
My wiser hub 2 was disconnected from the internet and flashing red. When I went in to the app to reconnect it I had lost all the programming except for one radiator micro module and one thermostat. I h...
134 0 2
DanIOM
/html/rank_icons/Crewman.png DanIOM
No longer able to add a new wiser device
I am no longer able to add a new wiser device (neither plug nor TRV) into the Wiser app. My existing home Hub setup with multiple TRV's continues to work, I can control the existing devices within ...
1157 0 17
Latest Reply: tank30
Lobman
Lobman
Issue with wiser not reaching set point.
We have a particular room in our house where the wiser hub doesn't ever seem to manage to get the room to it's set point. It's the coldest room in the house. We tend to set the temperature to 18.5C. ...
49 0 0
2025-11-18
Pyrotech
Pyrotech
Noisy smart thermostat heads
I have installed a wiser kit 1 to our 3 storey town house due to the temperature difference between floors. The system works well in conjunction with wet underfloor heating on the ground floor. However...
102 0 2
Latest Reply: Pyrotech
Bazza1878
Bazza1878
Wiser hub
Hi all, I’ve just installed the wiser hub and app and set up a heating schedule, my question is why does my boiler continue to fire past the scheduled time? i.e. I have set the temp at 20 degrees from ...
51 0 0
2025-11-18
mickiete
mickiete
Temperature Display Offset
Is there a way to offset the temperature reading display on the app by a room stat as the readings I am getting from the sensors are about 2 deg lower than the actual rooms after checking with other di...
109 0 1
Olympe
/html/rank_icons/Crewman.png Olympe
Firmware Passerelle Génération 2
Bonjour, j'ai 2 passerelle génération 2 (dans 2 endroits) mais l'une est restée à la version 4.18.36 alors que l'autre est en 4.42.23. les 2 sont connectées à internet (et au cloud wiser). le soucis c...
135 0 2
Latest Reply: Olympe
MalcolmSu
/html/rank_icons/Crewman.png MalcolmSu
Device firmware
Across all the devices I have connected to my Wiser hub, in each category, all the devices are on the same level of firmware, except for one. One Room Thermostat is several versions behind all the oth...
219 0 3
  • « Previous
    • 1
    • 2
    • 3
    • 28
  • Next »
