Can I connect a Wiser Relay (CCTFR6001) to a Wiser Gateway CCTFR6901G2 when one relay is already installed?
Select a Country
  • Can I connect a Wiser Relay (CCTFR6001) to a Wiser Gateway CCTFR6901G2 when one relay is already installed?
David_SE
David_SE Mentor
201
Alfred_SE
Alfred_SE Leader
24
Maude.wiser.
Maude.wiser. Contributor
22
Noctural
Noctural
Explorer
Posted: ‎2025-12-06 10:48 AM
539
I currently have a Wiser Gateway (model CCTFR6901G2) installed, along with its existing heating control setup.
I would like to add an additional Wiser Relay (CCTFR6001) to the same system in order to control a second independent heating device.
Before purchasing the module, I would like to confirm the following:
  1. Can the CCTFR6901G2 gateway pair with more than one relay (CCTFR6001) simultaneously?
  2. Does the Wiser Home app support managing two separate boiler/heat-source relays within a single installation?
  3. Are there any technical limitations or unsupported configurations when using multiple boiler relays with the same gateway?
I looked through the available documentation but couldn’t find a clear answer on whether this setup is officially supported.
Thank you in advance for your help and clarification.
  • Temperature Control
David_SE
David_SE Mentor
Mentor
Posted: ‎2025-12-16 06:18 AM
In response to Noctural
Hi @Noctural ,
Wiser Home system is not launched in Belgium but Wiser Home app is available as in the past, Wiser Energy solution was sold and some customers need to have a system for energy monitoring.
THe gateway you need is only sold in UK (2nd Generation | 2 Channel HubR | Smart Home Hubs), please check that gateway documentation before ordering if it will meet your needs (files)
BR
David
David_SE
David_SE Mentor
Mentor
Posted: ‎2025-12-09 12:17 AM
525
Hi @Noctural ,
It is not possible with these products. An alternative solution can be proposed but only sold in UK, where are you located ?
Thanks.
BR
David
Noctural
Noctural
Explorer
Posted: ‎2025-12-09 01:29 AM
In response to David_SE
518
Hi @David_SE,
I live in Belgium but what is the alternative solution?
David_SE
David_SE Mentor
Mentor
Hi @Noctural ,
BR
David
