  • Mark all as New
  • Mark all as Read
  • Float this item to the top
  • Invite a Friend
  • Threaded format
  • Linear Format
  • Sort by Topic Start Date
The message you are trying to access is permanently deleted.
wiser-logo
Conversation by Products
Explore our products forum and get answers to your questions:
Temperature control
Temperature control
Safety
Safety
Security
Security
Apps
Apps
Gateways
Gateways
Lighting
Lighting
Energy management
Energy management
Shutter and blind
Shutter and blind
Voice control
Voice control
Top Labels
Top Labels
  • Alphabetical
  • Temperature Control 91
  • Apps 68
  • About Wiser 59
  • Energy management 29
  • Gateways and Hubs 23
  • Bugs 19
  • Gateways 19
  • Lighting 14
  • Knowledge questions 14
  • Connectivity Devices 13
  • Mobile Applications 12
  • Shutter and Blind 12
  • Safety 11
  • Energy devices 11
  • Usability issues 10
  • Voice Control 8
  • Security 8
  • Announcements and Release Notes 7
  • OTHERS 7
  • User Testimonials 6
  • Ideas of improvements 5
  • Others & accessories 1
  • Did you know 1
  • Communicating Actuators and Energy Valves 1
  • Thermostats 1
  • Visual feedback 1
  • Previous
  • 1 of 2
  • Next
David_SE
Admiral David_SE Admiral
151
Alfred_SE
24
Maude.wiser.
22
Thumbnail of Wiser
Wiser
9
Thumbnail of Wiser for KNX : logic controller
6
Thumbnail of PowerLogic™ PowerTag
2
  • All
  • Solved
  • Unsolved
  • Unanswered
Informational
David_SE
Wiser Home app new version - v7.3.0 & Wiser Home Hub 2nd Gen new FW ve...
Dear Wiser user, A new Wiser Home app version v7.3.0 and a new Wiser Home Hub 2nd Gen FW version 4.42.23 will be deployed that week. In addition to bug fixes and enhancements, this release co...
Schneider Electric Wiser icon_circle Schneider Electric Wiser Forum
1496 1 5
Latest Reply: Zigzag5885
Alfred_SE
Welcome to the Schneider Electric Wiser Community!
Dear Wiser user, Interact with other #Wiser users while staying up to date on the newest news, features, and customer stories. Have a #Wiser Life! A whole new #Wiser environment for you to get to...
4997 9 3
Latest Reply: StewartT
MatthieuT
Ensign MatthieuT
Micromodule CCTFR6730 pour piloter plancher chauffant?
Bonjour, Je cherche à domotiser mon installation et je me demande s'il est possible d'associer le micromodule de charge CCTFR6730 à un thermostat dans l'appli Wiser en changeant le type et sélectionnan...
643 0 2
Latest Reply: YJ08
Lobman
Lobman
Issue with wiser not reaching set point.
We have a particular room in our house where the wiser hub doesn't ever seem to manage to get the room to it's set point. It's the coldest room in the house. We tend to set the temperature to 18.5C. ...
317 0 3
Latest Reply: Houseyhousey
JP-Org
Lieutenant | EcoXpert Master JP-Org Lieutenant | EcoXpert Master
Récupération des logs de la passerelle
Bonjour, Dans l'application Wiser Home, dans le Menu "Assistance" -- "Historique des Téléchargements", il y a la possibilité de télécharger un fichier journal de la passerelle. Bien, comme fonctionnali...
512 0 2
Latest Reply: JP-Org
lgo44
Lieutenant | EcoXpert Master lgo44 Lieutenant | EcoXpert Master
Wiser Home app : connexion
Je possède 3 passerelles Wiser, pour consulter les différents états depuis l'application il faut à chaque fois me déconnecter puis me reconnecter, c'est long et fastidieux. Dans mon cas Il faut en plus...
1061 0 5
Latest Reply: lgo44
PaoloF
PaoloF
Looking for a working APK for legacy Wiser system (EER21000 + EER53000...
Hello,I recently bought an apartment equipped with an older Wiser heating control system composed by: 1 x Wiser Controller EER21000 5 x Wiser Radiator Thermostats EER53000 1 x Wiser Smart Plug EE...
169 0 2
Latest Reply: PaoloF
Houseyhousey
Crewman Houseyhousey
Working stroke of Wiser Thermostatic Radiator valve
What is the actual working stroke of the Wiser radiator valve, as mine only seems to move about 1.5mm, but the pin on the valve moves about 3mm?
420 0 4
Kernow_Yardie
Kernow_Yardie
Eco Mode Question
Please look at image for message as get error saying message isn’t allowed.  
332 0 3
Latest Reply: Kernow_Yardie
Noctural
Noctural
Can I connect a Wiser Relay (CCTFR6001) to a Wiser Gateway CCTFR6901G2...
Hello,I currently have a Wiser Gateway (model CCTFR6901G2) installed, along with its existing heating control setup.I would like to add an additional Wiser Relay (CCTFR6001) to the same system in order...
198 0 2
Latest Reply: Noctural
astephon88
astephon88
Erratic Smart Radiator Thermostat Temp Readings
I've recently picked up a Gen1 HubR, a room thermostat and several radiator thermostats. The control of the room with the room thermostat has been stellar; however, the rooms with only radiator thermos...
414 0 5
Latest Reply: astephon88
JMatt
JMatt
Room Thermostat Issues... Again
We have had many issues with our Wiser Room Thermostat, and recently it has started to go offline for no apparent reason. We have tried replacing the batteries, moving it closer to the hub, resetting t...
167 0 1
Latest Reply: David_SE
Bazza1878
Bazza1878
Wiser hub
Hi all, I’ve just installed the wiser hub and app and set up a heating schedule, my question is why does my boiler continue to fire past the scheduled time? i.e. I have set the temp at 20 degrees from ...
269 0 2
  • « Previous
    • 1
    • 2
    • 3
    • 29
  • Next »
