IT Expert - Device not recognized
ITE Configuration
Detailed instructions for how to configure EcoStruxure IT Expert
  • EcoStruxure IT Help Center
  • IT Expert
  • Configuration
  • ITE Configuration
  • IT Expert - Device not recognized
  • Mark as Read
  • Service contract information in IT Expert
  • Service visit information in IT Expert
  • Device warranty information in IT Expert
  • Create locations in IT Expert
  • Create an alarm severity policy in IT Expert
  • Custom properties in IT Expert
  • Single device configuration
  • Outlet control in IT Expert
  • EcoStruxure IT authentication method
  • SMS authentication
  • Google, Duo, Auth0, or other authentication
  • Setting up call priority for Asset Advisor in IT E...
  • Configure EcoStruxure IT mobile app push notificat...
  • Rack ATS firmware update can cause permanent damag...
  • Configure event actions for APC SNMP devices in IT...
  • IT Expert - Device communication failure
  • IT Expert - Device is offline
EcoStruxure IT Support
Request Support
Back to ITE Configuration
  • Mark as Read
Picard EcoStruxureIT
‎2023-02-02 02:15 AM
Last Updated: Sisko JLehr Sisko ‎2024-09-03 07:13 AM
When the device status is Device not recognized or Device not ready in IT Expert, it is usually because the device IP address was reused, or the device is not configured properly in the Gateway.
Common reasons for failure
The device replaced an older device.
  • Remove the old device in the Gateway, and then discover the new device.
    It is important that the old offline device is removed from the Gateway before you discover the new device.
    How to replace a device in EcoStruxure IT Gateway
The device IP address was reused.
  • Make sure the IP address for the device is not being used by any other device in IT Expert. Go to Devices and type the IP address into the search bar.
  • Make sure the Gateway does not have any other devices registered with that IP address.
    If there are devices using the same IP address, remove the old device(s) and then rediscover the new one.
The device is on the wrong port.
  • Make sure port settings are correct on the device and in the in the Gateway.
IMPORTANT: After you make any changes to devices in the Gateway, you must rediscover the affected devices.
Some EcoStruxure IT features may not work properly when device IP addresses are not configured correctly.
