IT Expert - Device is offline
ITE Configuration
Detailed instructions for how to configure EcoStruxure IT Expert
  • EcoStruxure IT Help Center
  • IT Expert
  • Configuration
  • ITE Configuration
  • IT Expert - Device is offline
  • Mark as Read
  • Service contract information in IT Expert
  • Service visit information in IT Expert
  • Device warranty information in IT Expert
  • Create locations in IT Expert
  • Create an alarm severity policy in IT Expert
  • Custom properties in IT Expert
  • Single device configuration
  • Outlet control in IT Expert
  • EcoStruxure IT authentication method
  • SMS authentication
  • Google, Duo, Auth0, or other authentication
  • Setting up call priority for Asset Advisor in IT E...
  • Configure EcoStruxure IT mobile app push notificat...
  • Rack ATS firmware update can cause permanent damag...
  • Configure event actions for APC SNMP devices in IT...
  • IT Expert - Device communication failure
  • IT Expert - Device not recognized
EcoStruxure IT Support
Request Support
Back to ITE Configuration
  • Mark as Read
Picard EcoStruxureIT
‎2023-02-02 02:13 AM
Last Updated: Sisko JLehr Sisko ‎2024-09-08 11:59 AM
When the device status is Device not recognized or Device is offline in IT Expert, it is usually because IT Expert has lost communication with the Gateway or the device itself.
Common reasons for failure
The computer where the EcoStruxure IT Gateway is installed might be powered off.
Make sure the server or PC where the Gateway is installed is always on.
System requirements for EcoStruxure IT Gateway
The device is rebooting or is offline.
NMC settings allow for some devices to have scheduled shut-off periods. The device may be offline.
Log into the device. Check that there are no alarms present and it specifically states the device is online.
The device was turned on recently.
IT Expert uses polling to check whether or not devices are online or offline. An NMC device that was just turned on may take up to 20 minutes to show as online in ITE.
Learn more
IMPORTANT: If you make any changes on an NMC device, make sure you log out to reboot the card.
If you make any changes to device credentials in the Gateway, you must rediscover the affected devices.
When a device is offline, some EcoStruxure IT features may not work properly.
34% helpful (1/3)
