Google, Duo, Auth0, or other authentication
ITE Configuration
Detailed instructions for how to configure EcoStruxure IT Expert
  • EcoStruxure IT Help Center
  • IT Expert
  • Configuration
  • ITE Configuration
  • Google, Duo, Auth0, or other authentication
  • Mark as Read
  • Service contract information in IT Expert
  • Service visit information in IT Expert
  • Device warranty information in IT Expert
  • Create locations in IT Expert
  • Create an alarm severity policy in IT Expert
  • Custom properties in IT Expert
  • Single device configuration
  • Outlet control in IT Expert
  • EcoStruxure IT authentication method
  • SMS authentication
  • Setting up call priority for Asset Advisor in IT E...
  • Configure EcoStruxure IT mobile app push notificat...
  • Rack ATS firmware update can cause permanent damag...
  • Configure event actions for APC SNMP devices in IT...
  • IT Expert - Device communication failure
  • IT Expert - Device is offline
  • IT Expert - Device not recognized
EcoStruxure IT Support
Request Support
Back to ITE Configuration
  • Mark as Read
Picard EcoStruxureIT
‎2018-11-13 05:08 AM
You only need to set up an authentication method in EcoStruxure IT once. The application will remember your preferred method. Find the recommended authentication method here.
  • Log in to https://app.ecostruxureit.com/manage using a computer.
  • Choose and download 2-factor authentication method: Auth0 Guardian, Google, or another authenticator.
  • Scan QR the code on your screen.
  • Copy and save your recovery code.
    When you log in for the first time, you'll receive your recovery code. You can use this code to log in to https://app.ecostruxureit.com/manage when you don't have your mobile device. Check the box to acknowledge that you've saved your recovery code to continue. It is your responsibility to store it safely.
  • Verification and you're in!
See EcoStruxure IT authentication method
