EcoStruxure IT authentication method
ITE Configuration
Detailed instructions for how to configure EcoStruxure IT Expert
Select a Country
  • EcoStruxure IT Help Center
  • IT Expert
  • Configuration
  • ITE Configuration
  • EcoStruxure IT authentication method
  • Mark as Read
  • Service contract information in IT Expert
  • Service visit information in IT Expert
  • Device warranty information in IT Expert
  • Custom metrics report in IT Expert
  • NetBotz rack access control in IT Expert
  • Outlet control in IT Expert
  • Custom properties in IT Expert
  • Create locations in IT Expert
  • Create an alarm severity policy in IT Expert
  • Single device configuration
  • SMS authentication
  • Google, Duo, Auth0, or other authentication
  • Setting up call priority for Asset Advisor in IT E...
  • Configure EcoStruxure IT mobile app push notificat...
  • Rack ATS firmware update can cause permanent damag...
  • Configure event actions for APC SNMP devices in IT...
  • IT Expert - Device communication failure
  • IT Expert - Device is offline
  • IT Expert - Device not recognized
  • Environment page in IT Expert
  • Device connection status in IT Expert
EcoStruxure IT Support
Request Support
Back to ITE Configuration
  • Mark as Read
EcoStruxureIT
‎2018-11-13 03:48 AM
Last Updated: JLehr Champion ‎2025-06-11 04:48 AM
Looking for How to reset two-factor authentication (2FA)?
The EcoStruxure IT authentication system has been updated to support the latest security standards.
SMS is no longer recommended as the most secure authenticator. The new recommended method uses software authenticators for 2-factor authentication. This improves security and improves the experience in areas where SMS codes have been unreliable due to bad cellular reception.
You must now choose a 2-factor authentication method: EcoStruxure IT app, Google or another authenticator, or SMS. The recommended authentication is using your EcoStruxure IT app.
You can also choose Google or SMS. If you don't choose to authenticate using the EcoStruxure IT app, make sure your preferred authenticator is installed on your mobile device.
Setting up 2-factor authentication for existing users (recommended method)
New user? Start here
Setting up authentication is a one time configuration. The application will remember your preferred method on your next login.
  • Log in to your EcoStruxure IT account using a computer, not your mobile phone.
  • Select "I've already downloaded it" to use the EcoStruxure IT app as your authentication method.
  • Scan the QR code on your screen.
  • Copy and save recovery code. When you log in for the first time, you'll receive your recovery code. You can use this code to log in when you don't have your mobile device.
    Tick the box to acknowledge that you've saved your recovery code to continue. It is your responsibility to store it safely.
  • Verification and you're in!
The next time you log in to https://app.ecostruxureit.com/manage you'll get a push notification through your EcoStruxure IT app.
Logging in with 2-factor authentication
  • You can opt to remember the passcode in the browser. The passcode is remembered for 30 days.
  • A push notification is sent to your phone or through your app if you have it open.
Also see
SMS authentication
