Rack ATS firmware update can cause permanent damage to the device
ITE Configuration
Detailed instructions for how to configure EcoStruxure IT Expert
  • EcoStruxure IT Help Center
  • IT Expert
  • Configuration
  • ITE Configuration
  • Rack ATS firmware update can cause permanent damage to the device
  • Mark as Read
  • Service contract information in IT Expert
  • Service visit information in IT Expert
  • Device warranty information in IT Expert
  • Create locations in IT Expert
  • Create an alarm severity policy in IT Expert
  • Custom properties in IT Expert
  • Single device configuration
  • Outlet control in IT Expert
  • EcoStruxure IT authentication method
  • SMS authentication
  • Google, Duo, Auth0, or other authentication
  • Setting up call priority for Asset Advisor in IT E...
  • Configure EcoStruxure IT mobile app push notificat...
  • Rack ATS firmware update can cause permanent damag...
  • Configure event actions for APC SNMP devices in IT...
  • IT Expert - Device communication failure
  • IT Expert - Device is offline
  • IT Expert - Device not recognized
EcoStruxure IT Support
Request Support
Back to ITE Configuration
  • Mark as Read
Picard EcoStruxureIT
‎2022-09-07 02:58 AM
During a rack ATS (AP77XX) firmware update through IT Expert or other means, permanent damage to the device can occur if there is a load attached. The ATS switches back and forth between power sources during the update, which causes loads downstream of the device to drop and causes permanent damage to the rack ATS.
For more information, see this information bulletin.
To update the firmware on affected rack ATS devices through IT Expert, you are required to indicate that you understand you must disconnect the secondary input power source before applying the firmware update.
Affected Rack ATS models (AP77XX)
  • AP7721
  • AP7722A
  • AP7723
  • AP7724
  • AP7730
  • AP7731
  • AP7732
  • AP7750A
  • AP7752
  • AP7752J
  • AP7753
100% helpful (1/1)
