Outlet control in IT Expert
ITE Configuration
Detailed instructions for how to configure EcoStruxure IT Expert
  • EcoStruxure IT Help Center
  • IT Expert
  • Configuration
  • ITE Configuration
  • Outlet control in IT Expert
  • Mark as Read
  • Service contract information in IT Expert
  • Service visit information in IT Expert
  • Device warranty information in IT Expert
  • Create locations in IT Expert
  • Create an alarm severity policy in IT Expert
  • Custom properties in IT Expert
  • Single device configuration
  • EcoStruxure IT authentication method
  • SMS authentication
  • Google, Duo, Auth0, or other authentication
  • Setting up call priority for Asset Advisor in IT E...
  • Configure EcoStruxure IT mobile app push notificat...
  • Rack ATS firmware update can cause permanent damag...
  • Configure event actions for APC SNMP devices in IT...
  • IT Expert - Device communication failure
  • IT Expert - Device is offline
  • IT Expert - Device not recognized
EcoStruxure™ IT Expert
EcoStruxure IT Support
Request Support
Back to ITE Configuration
  • Mark as Read
Sisko JLehr Sisko
‎2023-09-18 07:21 AM
IT Expert Administrator users can control outlets on monitored APC switched rack PDUs in ITE from the Control option of the device details page, and in the Ecostruxure IT mobile app. An IT Expert subscription is required.
Outlet control for APC switched rack rPDUs requires EcoStruxure IT Gateway 1.15.1 or newer.
How to update EcoStruxure IT Gateway software
Outlet control for Easy Rack PDUs is not available in IT Expert at this time.
Outlet control for 10000 series rack PDUs is not available until the display module is replaced with APDU9640NMC3.
See Discover PDU in DCE or ITE after replacing the display module with APDU9640NMC3
IT Expert cannot determine which outlets are part of an outlet group.
When you perform a command at an outlet that is part of an outlet group configured on the device or in Data Center Expert, that command will be executed at all outlets in the group.
  1. Log in to your ecostruxureit.com account.
  2. Go to Devices, click the APC switched rack PDU device where you want to control the outlets, and then click the Control tab.
  3. Click an outlet, and then choose one of the outlet states:
    • Immediate On
    • Immediate Off
    • Immediate Reboot: The outlet state after a reboot is On regardless of whether of was off before it was rebooted.
    • Delayed On: Use the device user interface to set the length of time to delay.
    • Delayed Off: Use the device user interface to set the length of time to delay.
    • Delayed Reboot: Use the device user interface to set the length of time to delay.
    • Cancel Pending Command
    It can take up to five minutes to show the updated state depending on when the device is polled.
Note: If the device is discovered via SNMPv1, the SNMPv1 write community string must be configured on the device, and SNMPv1 credentials defined in the Gateway must match. You can modify the SNMPv1 credentials in the Gateway and then rediscover the device if necessary.
To disable the device control feature for your organization, contact support for assistance.
