Setting up call priority for Asset Advisor in IT Expert
ITE Configuration
Detailed instructions for how to configure EcoStruxure IT Expert
  • EcoStruxure IT Help Center
  • IT Expert
  • Configuration
  • ITE Configuration
  • Setting up call priority for Asset Advisor in IT Expert
  • Mark as Read
  • Service contract information in IT Expert
  • Service visit information in IT Expert
  • Device warranty information in IT Expert
  • Create locations in IT Expert
  • Create an alarm severity policy in IT Expert
  • Custom properties in IT Expert
  • Single device configuration
  • Outlet control in IT Expert
  • EcoStruxure IT authentication method
  • SMS authentication
  • Google, Duo, Auth0, or other authentication
  • Setting up call priority for Asset Advisor in IT E...
  • Configure EcoStruxure IT mobile app push notificat...
  • Rack ATS firmware update can cause permanent damag...
  • Configure event actions for APC SNMP devices in IT...
  • IT Expert - Device communication failure
  • IT Expert - Device is offline
  • IT Expert - Device not recognized
EcoStruxure IT Support
Request Support
Back to ITE Configuration
  • Mark as Read
Picard EcoStruxureIT
‎2020-01-30 04:29 AM
Last Updated: Sisko JLehr Sisko ‎2024-10-22 02:09 PM
This is required for EcoStruxure Asset Advisor subscribers.
If you use SSO for your organization, you must also configure your organization's users on the Administration > Users tab. Otherwise, the Schneider Electric Service Bureau cannot contact the individuals responsible in case of an incident.
In IT Expert, go to the Devices page and click the arrow next to Contacts to set up or edit the call priority used by the Schneider Electric Service Bureau to contact the individuals responsible, in order, in case of an incident.
You can set up call priority for your entire organization or for each location. The call priority is inherited through the location hierarchy. That is, the call priority you set at the highest level is inherited by all locations below it. You can change the call priority list further down in the hierarchy as needed.
Drag and drop contacts to change the order of priority.
Make sure you keep the call priority updated so the correct people are involved in critical incidents, for example, if responsibilities change hands.
See Manage users in IT Expert
