EBO Data Collection Summary
Select a Country
  • EBO Data Collection Summary
David_Purser Champion
‎2022-08-29 12:04 PM
Last Updated: ContentModerator Explorer ‎2025-08-11 04:10 AM
There is currently no summary KB article for all the data collection available in EBO systems.
  • Building Operation Enterprise Central
  • Building Operation Workstation
  • Building Operation Webstation
  • Building Operation Automation Server Premium
  • Building Operation Automation Server Bundled
Identified the need to review data from EBO to analyze performance or issues.
Purposes for Data Collection
  • Provide visual information about the issue
    • Screenshots (from Windows Snip & Sketch or other tools)
    • Video Capture or Mobile Device Video
    • Device LEDs, provide any information about them and when they change.
  • Provide information about your configuration/installation
    • Network devices, including routers, switches, and any configuration you can provide
    • BMS Routers
    • Site Topology, including all devices included in the communications path
  • Provide server (EC/ES/AS) XBK backup
    • Configuration only is smaller and useful when investigating configuration, bindings, and/or programming
    • All Data is larger and recommended when need to see trends or events to help investigate the issue's timeline.
  • Provide any information to replicate the issue.
    • Provide as specific as possible steps used to create that outcome
    • Provide VERSIONS of ALL software, hardware, and protocols involved
  • If submit any captures or logs, perform the following:
    • Provide any steps performed in EBO during the capture or log with the date & time, so these events can be matched.
Servers (EC/ES/AS)
  • Collect logs from an Automation Server
  • Collect logs from the Enterprise Server and Enterprise Central
  • Backing Up EcoStruxure BMS Servers Manually  (Configuration Only or All Data)
Server Fieldbus Protocols
  • Infinet: Gathering Trace Log information for the Infinet bus in EBO
  • Lon: (Video included)
    Analyze Lon communication using trace log in EBO
  • Modbus: Capture a Modbus trace log in EBO/SBO
Software
  • EBO Webstation
    • Collect EBO Webstation browser logs
  • EBO Workstation
    • Collect EBO Workstation logs
  • EBO Project Configuration Tool (PCT)
    • Collect log files from Project Configuration Tool (PCT)
  • Windows
    • Review the Windows Event Logs. What specifically happens when an error occurs?
      Follow this KB article to view and save the Windows Events: Viewing, Saving, Sharing Windows Event Logs for Troubleshooting Purposes
  • Wireshark
    • For extended period capturing, use this article to set up a Ring Buffer in Wireshark. Wireshark capture ring buffer for continuous capturing
Hardware
  • b3/Infinet Controller
    • Collect log from a b3 or Infinet controller
  • BACnet/IP Controller
    • Workstation method - BACnet/IP Controller Diagnostics
    • Building Commission method - Viewing and Exporting Diagnostic Files (WebHelp) or Viewing Diagnostic Files (YouTube)
Protocols & Electrical Interfaces
  • Ethernet
    • Capture any ethernet traffic, including IP: Using WireShark to analyse communications on an Ethernet network
    • Capture Loopback (127.0.0.1) traffic between applications and/or servers running on the same host OS: How to capture localhost traffic with Wireshark to help troubleshoot EWS communication issues
  • Lon
    • Using Loytec LPA with SpaceLogic Server AS-P
  • RS-485
    • Fieldbuses include BACnet MS/TP, I/Net, Infinet, Modbus RTU
    • BACnet MSTP Capture Application - Communities (se.com) aka mstpcap.exe
    • BACnet - PicoScope Basics
    • Picoscope Configuration for Modbus RTU capturing and decoding
    • Modbus RTU capturing in Wireshark
Tags (2)
  • DavidPurser22
  • PeterLarsen22
100% helpful (4/4)
