Collect log files from Project Configuration Tool (PCT)
  • Collect log files from Project Configuration Tool (PCT)
  • RandyDavis
    RandyDavis
  • RobertAndriolo
    RobertAndriolo
  • PeterEdvik
    PeterEdvik
  • StephenYang
    StephenYang
  • MikaelKrantz
    MikaelKrantz
‎2018-09-06 07:28 AM
Last Updated: Guinan RandyDavis Guinan ‎2020-04-15 10:50 AM
How to collect log files from the Project Configuration tool.
When contacting Product Support about issues with the Project Configuration tool, log files should be provided.
  1. Go to the PCT installation folder and run the program called LogCollector.exe located there.
    The default installation folder for versions 1.2 and higher is:
    "C:\Program Files (x86)\Schneider Electric EcoStruxure\Building Operation\Project Configuration Tool" and
    "C:\Program Files (x86)\Schneider Electric StruxureWare\Building Operation\Project Configuration Tool" for previous versions.
  2. Click Collect logs
  3. A program log of what LogCollector has done is displayed.
  4. A zip-file containing the collected PCT logs is created on the desktop.
Labels (2)
  • Project Configuration Tool
Tags (4)
  • 19874
  • log-files
  • PeterEdvik19
  • StephenYang20
67% helpful (2/3)
