  • Mark all as New
  • Mark all as Read
  • Float this item to the top
  • Invite a Friend
  • Threaded format
  • Linear Format
  • Sort by Topic Start Date
The message you are trying to access is permanently deleted.
wiser-logo
Conversation by Products
Explore our products forum and get answers to your questions:
Temperature control
Temperature control
Safety
Safety
Security
Security
Apps
Apps
Gateways
Gateways
Lighting
Lighting
Energy management
Energy management
Shutter and blind
Shutter and blind
Voice control
Voice control
Top Labels
Top Labels
  • Alphabetical
  • Temperature Control 82
  • Apps 68
  • About Wiser 59
  • Energy management 29
  • Gateways 19
  • Gateways and Hubs 16
  • Lighting 14
  • Connectivity Devices 12
  • Shutter and Blind 12
  • Safety 11
  • Knowledge questions 11
  • Bugs 11
  • Mobile Applications 10
  • Energy devices 10
  • Voice Control 8
  • Security 8
  • Announcements and Release Notes 7
  • OTHERS 7
  • Usability issues 7
  • User Testimonials 6
  • Ideas of improvements 3
  • Did you know 1
  • Communicating Actuators and Energy Valves 1
  • Thermostats 1
  • Visual feedback 1
  • Previous
  • 1 of 2
  • Next
David_SE
Captain David_SE Captain
137
Alfred_SE
24
Maude.wiser.
22
BrianT58
Lieutenant BrianT58
18
Thumbnail of Wiser
Wiser
7
Thumbnail of Wiser for KNX : logic controller
6
Thumbnail of PowerLogic™ PowerTag
2
  • All
  • Solved
  • Unsolved
  • Unanswered
Informational
David_SE
/html/rank_icons/Captain.png David_SE /html/rank_icons/SE-Employee.png
Wiser Home app new version - v7.3.0 & Wiser Home Hub 2nd Gen new FW ve...
Dear Wiser user, A new Wiser Home app version v7.3.0 and a new Wiser Home Hub 2nd Gen FW version 4.42.23 will be deployed that week. In addition to bug fixes and enhancements, this release co...
Schneider Electric Wiser icon_circle Schneider Electric Wiser Forum
231 1 1
Latest Reply: Fozzie1960
Alfred_SE
Alfred_SE /html/rank_icons/Retired-User.png
Welcome to the Schneider Electric Wiser Community!
Dear Wiser user, Interact with other #Wiser users while staying up to date on the newest news, features, and customer stories. Have a #Wiser Life! A whole new #Wiser environment for you to get to...
3664 9 3
Latest Reply: StewartT
Verelec
Verelec
Wiser2 (5200WHC2) failure after firmware (1.32.4) update with Piced 4....
Hi all, during a routine service call at a client I was kindly sked to perform a small change in the Wiser2 widgets. That is simple in itself except that the firmware update bricked the Wiser2 during t...
76 0 1
Latest Reply: David_SE
Verelec
Verelec
Failed CBus Wiser2 Firmware
Hi all, Wiser2 5200WHC2, Toolkit 1.19, Piced 4.14.2 firmware 1.32.4 during a routine service call at a client I was kindly sked to perform a small change in the Wiser2 widgets. That is simple in itse...
69 0 1
Martinez838
Martinez838
Wiser dimmer flashing LED Issue
Having issues with the wiser connected dimmer 41EPBDWCLMZ TV2522 / PDL354PBDMBTZ I have tried 3 separate dimmers to which all are having the same issue Issue: The white LED flashes 5 times, pause fo...
79 0 2
DanIOM
DanIOM
No longer able to add a new wiser device
I am no longer able to add a new wiser device (neither plug nor TRV) into the Wiser app. My existing home Hub setup with multiple TRV's continues to work, I can control the existing devices within ...
129 0 3
Informational
David_SE
231 1 1
Sjhridnehhxhen
Sjhridnehhxhen
New feature for iTRV's
Anyone else want to have a TRV that could control flow to a radiator to a certain temperature, but not be able to do a call for heat? I have 10mm piping so running heat to just one radiator, does not...
923 2 5
Latest Reply: Nuuki
VitBadger85
VitBadger85
SchneiderHome app will not proceed past login page
Hello all, I was in the mids of renovations in my house during last few months and missed the migration of Wiser device from WiserApp to SchneiderHome app. I tap login, it take me to a chrome browse...
90 0 1
Gr00vy58
Gr00vy58
Schneider home app
Schneider Home App is terrible, Sense app was superior to what you now have for customers. Are improvements going to be made for Schneider Home App, or are you just going to hang your customers out to...
194 0 2
BartinFrance
BartinFrance
Wiser home app Login
I use the Wiser Home app on an iPhone 12 iOS 18.6.2. I have two hubs, so I have to log in and out with my email address and password to switch between hubs. This information is stored in my smartphone'...
79 0 1
wheelsandcogs
wheelsandcogs
Wiring 2 port zone valve to Wiser UFH controller
Hi, I'm currently wiring up a Wiser UFH Controller for the first time. The wiring for the pump seems relatively straightforward as it only has 3 cores (L, N, E). I have a Reliance 2-port motorised va...
117 0 2
Latest Reply: wheelsandcogs
CyrilShanks
CyrilShanks
Wiring the back plate
I am trying to wire the backplate for the hub. I am replacing a Honeywell BDR91 unit. I have attached a picture of the wiring plate and I wondered if someone can confirm which wires connect to the new ...
125 0 2
Latest Reply: CyrilShanks
  • « Previous
    • 1
    • 2
    • 3
    • 26
  • Next »
