NFS mount error in IT Advisor
ITA FAQ
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA FAQ
  • NFS mount error in IT Advisor
  • Mark as Read
  • What to do before starting an ITA upgrade
  • Select Custom Properties in the ITA web client
  • Asset visuals in ITA web client
  • Cannot run the IT Advisor desktop client on Mac
  • Are Active Directory and similar integrations avai...
  • Work Order email notifications
  • What counts as a license node in ITA?
  • Upgrading IT Advisor
  • Single sign on in EcoStruxure IT
  • Resetting the user password on the ITA server
  • Reset password for the ITA client
  • Path to migrate from StruxureWare Data Center Oper...
  • NetBotz 750 temperature sensors do not appear in I...
  • Is the REST API the same for both on-premise and h...
  • Is the ETL integration going away in IT Advisor?
  • Integrating IT Optimize in ITA: Failed to connect ...
  • ITA on-premise step by step installation
  • ITA genome policy
  • Can I model rack mounted UPS and PDU?
  • How to update the Genome Library in ITA
  • Can I model a parallel UPS system?
  • How to start ITA client in a different language
  • Can I migrate/merge from another ITA or DCO
  • How to start EcoStruxure IT Advisor client in a di...
  • Can I log in to IT Advisor using single sign on (S...
  • How to restore a backup file
  • Can I connect more than one rack ATS to a rack PDU
  • How to report an issue
  • Are Insight and Energy Efficiency available in IT ...
  • How to register an IT Advisor server in EcoStruxur...
  • Adding customer via ITA REST web service api
  • How to model a server room
  • How to enable SSL protocol to accept only TLSv1.2 ...
  • How to disable SNMPv1 in ITA
  • How to create a new user to login to the server
  • How to check whether an ITA backup is completed
  • How to associate or unassociate devices from the i...
  • How to add a license in ITA
  • Faulty ”future check” error: It seems the server w...
  • Differences between DCO and ITA
  • Desktop client login issue possible after updating...
  • Configuring email settings in ITA
  • Can I upgrade to ITA on-premise if I have a perpet...
  • Can I upgrade my DCO 7.5 setup to latest ITA?
  • ITA genome policy
EcoStruxure IT Support
Request Support
Back to ITA FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2020-11-20 12:01 AM
If the NFS utility is not installed on your IT Advisor or DCO server, you'll see an error when you try to add NFS as a mount type.
Failed to save mount : NFS Error - mount: wrong fs type, bad option, bad superblock on xxxx, missing codepage or helper program, or other error (for several filesystems (e.g. nfs, cifs) you might need a /sbin/mount. helper program) In some cases useful info is found in syslog - try dmesg | tail or so.
SSH into the server and run the following command to install the required packages:
sudo yum -y install nfs-utils
Note: The ITA or DCO server must have internet access.
