Upgrading IT Advisor
ITA FAQ
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA FAQ
  • Upgrading IT Advisor
  • Mark as Read
  • What to do before starting an ITA upgrade
  • Select Custom Properties in the ITA web client
  • Asset visuals in ITA web client
  • Cannot run the IT Advisor desktop client on Mac
  • Are Active Directory and similar integrations avai...
  • Work Order email notifications
  • What counts as a license node in ITA?
  • Single sign on in EcoStruxure IT
  • Resetting the user password on the ITA server
  • Reset password for the ITA client
  • Path to migrate from StruxureWare Data Center Oper...
  • NetBotz 750 temperature sensors do not appear in I...
  • NFS mount error in IT Advisor
  • Is the REST API the same for both on-premise and h...
  • Is the ETL integration going away in IT Advisor?
  • Integrating IT Optimize in ITA: Failed to connect ...
  • ITA on-premise step by step installation
  • ITA genome policy
  • Can I model rack mounted UPS and PDU?
  • How to update the Genome Library in ITA
  • Can I model a parallel UPS system?
  • How to start ITA client in a different language
  • Can I migrate/merge from another ITA or DCO
  • How to start EcoStruxure IT Advisor client in a di...
  • Can I log in to IT Advisor using single sign on (S...
  • How to restore a backup file
  • Can I connect more than one rack ATS to a rack PDU
  • How to report an issue
  • Are Insight and Energy Efficiency available in IT ...
  • How to register an IT Advisor server in EcoStruxur...
  • Adding customer via ITA REST web service api
  • How to model a server room
  • How to enable SSL protocol to accept only TLSv1.2 ...
  • How to disable SNMPv1 in ITA
  • How to create a new user to login to the server
  • How to check whether an ITA backup is completed
  • How to associate or unassociate devices from the i...
  • How to add a license in ITA
  • Faulty ”future check” error: It seems the server w...
  • Differences between DCO and ITA
  • Desktop client login issue possible after updating...
  • Configuring email settings in ITA
  • Can I upgrade to ITA on-premise if I have a perpet...
  • Can I upgrade my DCO 7.5 setup to latest ITA?
  • ITA genome policy
EcoStruxure IT Support
Request Support
Back to ITA FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2021-06-01 09:17 PM
Last Updated: Captain gsterling Captain ‎2024-10-07 10:16 AM
The latest version of IT Advisor is available to customers with an active software support contract only.
Customers with an active support contract can get access to newly released product updates on the EcoStruxure IT Entitlements portal.
Log in and then click Software Updates. More information...
If the ITA update files are not available in EcoStruxure IT Entitlements, contact your local technical support to verify your support contract and get access to the update file(s) you need.
Upgrading to the latest ITA version
From version 9.3.x
Upgrade or backup/restore
  • A direct upgrade to 9.3.x/9.4.x/9.5.x is supported
From version 9.1.x
  • A direct upgrade to 9.2.x is supported.
  • A direct upgrade from 9.1.x/9.2.x to 9.3.0 is supported if the server has internet access during the upgrade.
  • Upgrade to version 9.3.x is not supported with offline version. Take a backup of the solution, perform a fresh install, and then restore the backup.
From version 9.0.x
Backup/restore only
  • The database and OS is updated to a later version in ITA 9.1.x/9.2.x, so updating from 9.0.x requires a clean installation of the latest version of ITA. Backup your ITA 9.0.x setup and then restore the backup file.
See
Upgrading from DCO 8.x to IT Advisor
How to add a license in IT Advisor
Recommendations and best practices
  • Do the upgrade test on a test setup, especially if the setup contains custom integrations. When you are satisfied with the successful upgrade, apply on the production setup.
  • Take a fresh backup file and save somewhere safe before doing any major changes and/or upgrading the setup.
  • Make sure the server and application is running fine before doing the upgrade. This can be verified in the server Webmin Status page https://<ITA server IP>:10000. Go to EcoStruxure IT Advisor > Status.
  • Make sure there is enough free disc space at ‘/’ partition. The upgrade file(s) are usually large. approximately 2+ GB, so the installer may need at least 5 GB free storage capacity to do the job.
Saving a backup file from existing setup (ITA server)
  1. Log in to the ITA web client https://<ITA server IP>
  2. Go to Administration > Backup and Restore.
  3. Select Schedule Backup.
  4. Enter a comment. such as Pre-upgrade, and then click OK.
Setting up a new server with a clean installation of ITA
For the entire installation process, see Installing IT Advisor (on-premises)
Restoring the backup file on the new server
  1. Upload the backup file to the new server default backup file(s) location: /data/backup.
  2. Log in to the ITA web client https://<ITA server IP>
  3. Go to Administration > Backup and Restore.
  4. Select the Restore option for your backup file
    Note: The Backup and Restore page also has an Upload Backups option to upload your backup file.
Upgrading using the latest ISO file
Depending on the and complexity of the setup, an update may take at least 15 minutes.
Make sure you have a fresh backup file saved on a remote location.
  1. Download the .iso file from a location provided by the support team. Copy the SHA256 key from the same location.
  2. Upload the .iso file to the server and place it in the  /data folder.
  3. Log in to Webmin https://<ITA server IP>:10000
  4. In the left menu, select EcoStruxure IT Advisor > Upgrade.
  5. In Full path to local EcoStruxure IT Advisor Installer file, select the uploaded .iso file from the  /data folder.
  6. In SHA256 checksum from the download page copy and paste the SHA256 checksum from the downloaded file.
  7. Click Upgrade.
IMPORTANT: Before starting the upgrade, make sure you have enough free disc space (at least 5 GB) specially on the root '/' partition.
Do not interrupt the upgrade process!
You can open a new browser window or tab and check the server application status in Webmin. Go to EcoStruxure IT Advisor >  Status.
When you have completed the update, you can launch the web client and download the ITA desktop client installer if needed.
