Single sign on in EcoStruxure IT
ITA FAQ
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA FAQ
  • Single sign on in EcoStruxure IT
  • Mark as Read
  • What to do before starting an ITA upgrade
  • Select Custom Properties in the ITA web client
  • Asset visuals in ITA web client
  • Cannot run the IT Advisor desktop client on Mac
  • Are Active Directory and similar integrations avai...
  • Work Order email notifications
  • What counts as a license node in ITA?
  • Upgrading IT Advisor
  • Resetting the user password on the ITA server
  • Reset password for the ITA client
  • Path to migrate from StruxureWare Data Center Oper...
  • NetBotz 750 temperature sensors do not appear in I...
  • NFS mount error in IT Advisor
  • Is the REST API the same for both on-premise and h...
  • Is the ETL integration going away in IT Advisor?
  • Integrating IT Optimize in ITA: Failed to connect ...
  • ITA on-premise step by step installation
  • ITA genome policy
  • Can I model rack mounted UPS and PDU?
  • How to update the Genome Library in ITA
  • Can I model a parallel UPS system?
  • How to start ITA client in a different language
  • Can I migrate/merge from another ITA or DCO
  • How to start EcoStruxure IT Advisor client in a di...
  • Can I log in to IT Advisor using single sign on (S...
  • How to restore a backup file
  • Can I connect more than one rack ATS to a rack PDU
  • How to report an issue
  • Are Insight and Energy Efficiency available in IT ...
  • How to register an IT Advisor server in EcoStruxur...
  • Adding customer via ITA REST web service api
  • How to model a server room
  • How to enable SSL protocol to accept only TLSv1.2 ...
  • How to disable SNMPv1 in ITA
  • How to create a new user to login to the server
  • How to check whether an ITA backup is completed
  • How to associate or unassociate devices from the i...
  • How to add a license in ITA
  • Faulty ”future check” error: It seems the server w...
  • Differences between DCO and ITA
  • Desktop client login issue possible after updating...
  • Configuring email settings in ITA
  • Can I upgrade to ITA on-premise if I have a perpet...
  • Can I upgrade my DCO 7.5 setup to latest ITA?
  • ITA genome policy
EcoStruxure IT Support
Request Support
Back to ITA FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2020-03-10 10:14 PM
Administrators can give users the option to use single sign on as the authentication method for EcoStruxure IT applications.
Important
All users using single sign on must be part of same EcoStruxure IT organization.
An administrator user is created when you sign up for EcoStruxure IT and is automatically placed in the Default User Group. When you invite users to join your organization, they are automatically added to the Default User Group.
To enable single sign on:
  1. Specify a Default User Group.
  2. Create or invite users.
Specifying a default user group
To specify an existing user group as the Default User Group:
  1. Log in to EcoStruxure IT.
  2. Go to Administration > User Groups.
  3. Click the user group you want to designates as the Default User Group and click Set as Default User Group.
To create a new user group to be the Default User Group:
  3. Add a new user group and click Set as Default User Group.
Creating users
Users are automatically added to the Default User Group when they log in to EcoStruxure IT for the first time.
You can also invite users to join your organization. The user will automatically be added to the Default User Group you specified.
  1. Go to Administration > Users > Add User > Single Sign On.
  2. Enter the email address and full name of the individual you want to invite.
All users must use single sign on as their authentication method. If you want to change that, you can disable it in Administration > Users.
  1. Select the user you want to sign in using their username and password option.
  2. Select Edit user and remove Force User to Use Single Sign On.
  3. Reset the user's password.
Single Sign On
Web client
On the web client login page, click LOG IN WITH ECOSTRUXURE IT.
Desktop client
  1. Start EcoStruxure IT Advisor.
  2. Go to Advanced Settings and Select Use SSO.
  3. Now you can click LOG IN WITH ECOSTRUXURE IT.
Note: When you log in using SSO for the first time, your browser might block a pop-up window. This results in the desktop client waiting for authentication. You can click on a blocked pop-up and allow opening it for this site.
