How to model a server room
ITA FAQ
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA FAQ
  • How to model a server room
  • Mark as Read
  • What to do before starting an ITA upgrade
  • Select Custom Properties in the ITA web client
  • Asset visuals in ITA web client
  • Cannot run the IT Advisor desktop client on Mac
  • Are Active Directory and similar integrations avai...
  • Work Order email notifications
  • What counts as a license node in ITA?
  • Upgrading IT Advisor
  • Single sign on in EcoStruxure IT
  • Resetting the user password on the ITA server
  • Reset password for the ITA client
  • Path to migrate from StruxureWare Data Center Oper...
  • NetBotz 750 temperature sensors do not appear in I...
  • NFS mount error in IT Advisor
  • Is the REST API the same for both on-premise and h...
  • Is the ETL integration going away in IT Advisor?
  • Integrating IT Optimize in ITA: Failed to connect ...
  • ITA on-premise step by step installation
  • ITA genome policy
  • Can I model rack mounted UPS and PDU?
  • How to update the Genome Library in ITA
  • Can I model a parallel UPS system?
  • How to start ITA client in a different language
  • Can I migrate/merge from another ITA or DCO
  • How to start EcoStruxure IT Advisor client in a di...
  • Can I log in to IT Advisor using single sign on (S...
  • How to restore a backup file
  • Can I connect more than one rack ATS to a rack PDU
  • How to report an issue
  • Are Insight and Energy Efficiency available in IT ...
  • How to register an IT Advisor server in EcoStruxur...
  • Adding customer via ITA REST web service api
  • How to enable SSL protocol to accept only TLSv1.2 ...
  • How to disable SNMPv1 in ITA
  • How to create a new user to login to the server
  • How to check whether an ITA backup is completed
  • How to associate or unassociate devices from the i...
  • How to add a license in ITA
  • Faulty ”future check” error: It seems the server w...
  • Differences between DCO and ITA
  • Desktop client login issue possible after updating...
  • Configuring email settings in ITA
  • Can I upgrade to ITA on-premise if I have a perpet...
  • Can I upgrade my DCO 7.5 setup to latest ITA?
  • ITA genome policy
EcoStruxure IT Support
Request Support
Back to ITA FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2020-08-20 11:40 PM
Here is a simple illustration of how to create a server room, add equipment, and configure the power path.
Create server room
In the desktop client, Planning Data Center mode, right click Global and select New > New Server Room.
Give it a name, and then define the room's Floor and Ceiling settings.
Add equipment from the Genome Library to Genomes
In this example the following equipment will be modeled, so will be added to Genomes (from the Genome Library):
  • UPS (40 KW)
  • PDU (40KW)
  • Breaker Modules
  • Rack
  • Rack PDU
  • Server
Model floor standing equipment
Drag floor standing equipment (UPS, PDU, and Rack) from Genomes and drop/place it on the opened room floor:
Model rack mounted equipment
Click on the rack, so you can see it in the rack view. Drag equipment (such as rPDU and server) from Genomes into the rack in the rack view:
Name the modeled equipment
To name the modeled equipment, right click the equipment, and then select Properties > General and enter the equipment name:
Configure Power path
Right click the UPS, and then select Properties > Power and define the connected power comsumer (such as PDU), Redundancy settings (such as A-Feed), and Power Path Color:
Right click the PDU, and select Properties > Power. Define the Output voltage settings:
In the PDU Properties > Power , select Breaker Panel. Click Add panel and then select/define the power consumer(s):
Right the server, and then select Properties > Power and define its power settings/power cable connection:
Comments
nbastien
nbastien
Cadet
  • Mark as Read
‎2024-07-25 11:34 AM
How can we clone a server room with all its content and work on it in a planning mode?  We want to start from the existing rack inventory and move equipment for a more optimal layout ...The new layout will then be used to create a new room as part of a datacenter move to a new building
Captain
  • Mark as Read
‎2024-07-29 03:30 AM
It is possible in the ITA desktop client to right click on an open room, choose copy. Then you can paste the room and make a copy as long as you paste the room into a separate location (folder) as ITA does not allow the duplicate to be created in the same location folder.
Also, please note any replicated racks will consume licenses. Most attributes are copied, but some are reset like your asset names may be reset to defaults.
Regards
Greg Sterling
Ninh_NV
Ensign Ninh_NV Ensign
Ensign
  • Mark as Read
‎2025-01-24 01:43 AM
Hello ITA expert,
How can we declare width and length of the room. I did not find any field to do it.
Ninh
