Resetting the user password on the ITA server
ITA FAQ
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA FAQ
  • Resetting the user password on the ITA server
  • Mark as Read
  • What to do before starting an ITA upgrade
  • Select Custom Properties in the ITA web client
  • Asset visuals in ITA web client
  • Cannot run the IT Advisor desktop client on Mac
  • Are Active Directory and similar integrations avai...
  • Work Order email notifications
  • What counts as a license node in ITA?
  • Upgrading IT Advisor
  • Single sign on in EcoStruxure IT
  • Reset password for the ITA client
  • Path to migrate from StruxureWare Data Center Oper...
  • NetBotz 750 temperature sensors do not appear in I...
  • NFS mount error in IT Advisor
  • Is the REST API the same for both on-premise and h...
  • Is the ETL integration going away in IT Advisor?
  • Integrating IT Optimize in ITA: Failed to connect ...
  • ITA on-premise step by step installation
  • ITA genome policy
  • Can I model rack mounted UPS and PDU?
  • How to update the Genome Library in ITA
  • Can I model a parallel UPS system?
  • How to start ITA client in a different language
  • Can I migrate/merge from another ITA or DCO
  • How to start EcoStruxure IT Advisor client in a di...
  • Can I log in to IT Advisor using single sign on (S...
  • How to restore a backup file
  • Can I connect more than one rack ATS to a rack PDU
  • How to report an issue
  • Are Insight and Energy Efficiency available in IT ...
  • How to register an IT Advisor server in EcoStruxur...
  • Adding customer via ITA REST web service api
  • How to model a server room
  • How to enable SSL protocol to accept only TLSv1.2 ...
  • How to disable SNMPv1 in ITA
  • How to create a new user to login to the server
  • How to check whether an ITA backup is completed
  • How to associate or unassociate devices from the i...
  • How to add a license in ITA
  • Faulty ”future check” error: It seems the server w...
  • Differences between DCO and ITA
  • Desktop client login issue possible after updating...
  • Configuring email settings in ITA
  • Can I upgrade to ITA on-premise if I have a perpet...
  • Can I upgrade my DCO 7.5 setup to latest ITA?
  • ITA genome policy
EcoStruxure IT Support
Request Support
Back to ITA FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2020-08-18 08:42 AM
These instructions apply to the OS user on the ITA server, that is, the user used during the ITA server installation process, and not the ITA user on the desktop and web clients.
To reset the user password on the ITA server:
  1. Insert the ITA installation media (USB key, DVD, or out-of-band management (OOM) interface) and reboot the server and ensure the ITA installation media is booted up.
  2. In the installation boot menu select Troubleshooting and then select Rescue a CentOS system.
  3. In rescue mode you are presented with 4 options. Type 1 for 1) Continue and press <return>.
  4. When you see Rescue Mount, press <return> and type chroot /mnt/sysimage.
  5. To change the password type passwd <username> where <username> is the name of the user created during setup.
  6. Type the new password.
  7. To exit chroot type: exit.
  8. Reboot the server by typing reboot.
  9. Remember to remove the ITA installation media.
Comments
Mr._T
Mr._T Cadet
Cadet
  • Mark as Read
‎2025-06-24 04:19 AM
Hi Team,
What is the best approach for resetting the Webmin Root Account Password on ITA v9.5.1?
Tafadzwa.
Captain
  • Mark as Read
‎2025-06-25 05:01 AM
Hello Mr._T, its been a while since I've had the pleasure to respond to you.
Are you able to login to your IT Advisor server using SSH as the root user? Normally the webmin root password is the same as the operating system (rocky linux) root password. If you run this command after you have logged into the ITA server using SSH:
sudo cat /etc/webmin/miniserv.users
the output will list all of the users defined to use webmin. If you see "root:x:0" in the output, the "x" means the operating system password is being used for root. If there's a hash in the ":x:" field then a password for root's webmin user was set... if you edit that field, replace the hash with the ":x:" like above then the operating system root password will be used. If you can run "sudo" then you can reset the root password (those instructions are further below).
Does your setup/configuration include a defined administrator user setup when the operating system was installed? Many customers define an "apc" user but it of course may be something else. If that user was defined as an administrator user then it should also be able to login to webmin. Once logged in, you can use webmin's users view to change passwords.
Or if you can login to the rocky linux operating system using SSH, and use "sudo" you can try changing root's password, then try logging into webmin using those credentials.
sudo passwd root
Regards
Greg Sterling
Mr._T
Mr._T Cadet
Cadet
  • Mark as Read
‎2025-06-25 09:26 AM
Hi @gsterling
Thank you for your feedback as always.
I have not gone back to the customer since I posted that question however I managed to play around on our Test environment and I eventually got it right using the steps mentioned in the original post.
It just seems like some options have changed since moving from DCO to ITA affecting step 1.
Tafadzwa.
