How to associate or unassociate devices from the integrated external system
ITA FAQ
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA FAQ
  • How to associate or unassociate devices from the integrated external system
  • Mark as Read
  • What to do before starting an ITA upgrade
  • Select Custom Properties in the ITA web client
  • Asset visuals in ITA web client
  • Cannot run the IT Advisor desktop client on Mac
  • Are Active Directory and similar integrations avai...
  • Work Order email notifications
  • What counts as a license node in ITA?
  • Upgrading IT Advisor
  • Single sign on in EcoStruxure IT
  • Resetting the user password on the ITA server
  • Reset password for the ITA client
  • Path to migrate from StruxureWare Data Center Oper...
  • NetBotz 750 temperature sensors do not appear in I...
  • NFS mount error in IT Advisor
  • Is the REST API the same for both on-premise and h...
  • Is the ETL integration going away in IT Advisor?
  • Integrating IT Optimize in ITA: Failed to connect ...
  • ITA on-premise step by step installation
  • ITA genome policy
  • Can I model rack mounted UPS and PDU?
  • How to update the Genome Library in ITA
  • Can I model a parallel UPS system?
  • How to start ITA client in a different language
  • Can I migrate/merge from another ITA or DCO
  • How to start EcoStruxure IT Advisor client in a di...
  • Can I log in to IT Advisor using single sign on (S...
  • How to restore a backup file
  • Can I connect more than one rack ATS to a rack PDU
  • How to report an issue
  • Are Insight and Energy Efficiency available in IT ...
  • How to register an IT Advisor server in EcoStruxur...
  • Adding customer via ITA REST web service api
  • How to model a server room
  • How to enable SSL protocol to accept only TLSv1.2 ...
  • How to disable SNMPv1 in ITA
  • How to create a new user to login to the server
  • How to check whether an ITA backup is completed
  • How to associate or unassociate devices from the i...
  • How to add a license in ITA
  • Faulty ”future check” error: It seems the server w...
  • Differences between DCO and ITA
  • Desktop client login issue possible after updating...
  • Configuring email settings in ITA
  • Can I upgrade to ITA on-premise if I have a perpet...
  • Can I upgrade my DCO 7.5 setup to latest ITA?
  • ITA genome policy
EcoStruxure IT Support
Request Support
Back to ITA FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2020-08-19 10:47 PM
Last Updated: Sisko JLehr Sisko ‎2024-02-20 09:57 AM
You can get device data such as power measurements, sensor/temperature values, and alarms into IT Advisor by associating devices from an integrated system such as IT Expert and Data Center Expert.
To associate
This example illustrates how to associate a monitored device from the integrated external system.
  1. In the ITA desktop client, go to Planning Device Association mode (1), then Unassociated Devices (2).
  2. Find the device that you want to associate.
    TIP: Use the Search filter (3) to locate the device. Search by device name, IP address, model name, etc.
  3. Click the located device (4) and hold, then drag it to its model in ITA (5).
That's it!
The device is associated and you can get device data from the integrated external system.
To verify, right click the associated device, and then go to Properties > External Systems > Device.
The device in this example, a rack PDU, displays the power data:
To unassociate
  1. Go to Planning Device Association mode (1), Navigation (2).
  2. Find the device to unassociate (3).
  3. Right-click the device and then select the Unassociate from equipment option (4).
100% helpful (1/1)
