ITA on-premise step by step installation
ITA FAQ
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA FAQ
  • ITA on-premise step by step installation
  • Mark as Read
  • What to do before starting an ITA upgrade
  • Select Custom Properties in the ITA web client
  • Asset visuals in ITA web client
  • Cannot run the IT Advisor desktop client on Mac
  • Are Active Directory and similar integrations avai...
  • Work Order email notifications
  • What counts as a license node in ITA?
  • Upgrading IT Advisor
  • Single sign on in EcoStruxure IT
  • Resetting the user password on the ITA server
  • Reset password for the ITA client
  • Path to migrate from StruxureWare Data Center Oper...
  • NetBotz 750 temperature sensors do not appear in I...
  • NFS mount error in IT Advisor
  • Is the REST API the same for both on-premise and h...
  • Is the ETL integration going away in IT Advisor?
  • Integrating IT Optimize in ITA: Failed to connect ...
  • ITA genome policy
  • Can I model rack mounted UPS and PDU?
  • How to update the Genome Library in ITA
  • Can I model a parallel UPS system?
  • How to start ITA client in a different language
  • Can I migrate/merge from another ITA or DCO
  • How to start EcoStruxure IT Advisor client in a di...
  • Can I log in to IT Advisor using single sign on (S...
  • How to restore a backup file
  • Can I connect more than one rack ATS to a rack PDU
  • How to report an issue
  • Are Insight and Energy Efficiency available in IT ...
  • How to register an IT Advisor server in EcoStruxur...
  • Adding customer via ITA REST web service api
  • How to model a server room
  • How to enable SSL protocol to accept only TLSv1.2 ...
  • How to disable SNMPv1 in ITA
  • How to create a new user to login to the server
  • How to check whether an ITA backup is completed
  • How to associate or unassociate devices from the i...
  • How to add a license in ITA
  • Faulty ”future check” error: It seems the server w...
  • Differences between DCO and ITA
  • Desktop client login issue possible after updating...
  • Configuring email settings in ITA
  • Can I upgrade to ITA on-premise if I have a perpet...
  • Can I upgrade my DCO 7.5 setup to latest ITA?
  • ITA genome policy
EcoStruxure IT Support
Request Support
Back to ITA FAQ
  • Mark as Read
Picard EcoStruxureIT
‎2019-10-08 12:43 AM
In the initial installation menu, select Install.
Press the Enter key to begin the installation process.
Select English/English (United States), and then Continue.
It may work with other languages as well.
Click Date & Time.
Select time zone, define Region and City, Network Time: On, and then click Done.
Click KEYBOARD.
Select/add the keyboard you want, and then click Done.
Click INSTALLATION DESTINATION.
Select "I will configure partitioning." and make sure that the root partition "/" gets most of the storage capacity.
Accept Changes and then Done.
Click NETWORK & HOST NAME.
Make sure Ethernet is ON, define Host name, Configure the IP settings, and then Done.
Click Begin Installation.
Click ROOT PASSWORD.
Enter your root password, and then Done.
Click USER CREATION
Enter user name and password, enable "Make this user administrator" and "Require a password to use this account", and then Done
Note: Avoid using "root" as user name . For security reasons, root login has been disabled in ITA.
 The log in session will be displayed when the installation is completed.
To get/verify the server IP, log in and then type sudo ifconfig
To verify if the application is running and ready to be used, log in to server Webmin interface (https:<ITA server IP>:10000), and then go to EcoStruxure IT Advisor > Status.
The ITA application uses a different set of users than the server/Linux users that we used above.
On a just installed server (where no backup file has been restored) a default user will be created with the username/password of apc/apc. Log in to the web-client (https://<ITA server IP>) to change the password.
Accept the self-signed certificate if browser should prompted for that. Type in apc/apc as login
Type in apc as existing password, and select a new one (at least 6 characters long)
