2018 IT Expert release notes
What's new in IT Expert
Get the latest news, release notes, and other need-to-know information about EcoStruxure IT Expert.
Send InviteCancel
The EcoStruxure IT/StruxureOn authentication system was updated to improve security.
SMS is no longer recommended as the most secure authenticator. You must now choose a 2-factor authentication method. This improves security and improves the experience in areas where SMS codes have been unreliable due to bad cellular reception.
To set up authentication, log in and choose a 2-factor authentication method: EcoStruxure IT app (recommended), Google or another authenticator, or SMS.
A link to the Gateway download page is provided once you are logged it. The download page has a link to download the Gateway and instructions on how to set up the software.
2. Enter the code that was sent to your mobile phone.
3. Click the link to download the Gateway software to connect your on-premise devices to the EcoStruxure Cloud. Instructions on how to set up the Gateway after you download and install it are also on the download page.
The Premium Upgrades option was removed from the Settings page.
You now upgrade devices to Premium in the device list. Select the devices you want to upgrade and click Upgrade to Premium... .
Note: The Upgrade to Premium... and Move to... buttons are not activated until you select at least one device.
Device hierarchy by site
November 2017
There is a new Manage Hierarchy option on the struxureon.com/manage page, available to admin users only. All users can view the hierarchy; only admin users can create or modify it.
You can see the hierarchy in the mobile app, but it is created or modified on struxureon.com, not in the app.
Two levels of organization: sites and rooms.
Add as many sites as needed. Add as many rooms within sites as needed.
Link Gateways or Data Center Experts to a site or to a room.
Link assets to a site or to a room.
Define a specific call priority list for each site.
New StruxureOn customers can create their device hierarchy from scratch. Existing customers will see that a hierarchy was created for them on struxureon.com based on their Gateway or DCE structure. This hierarchy can then be modified on struxureon.com
Creating a hierarchy is optional.
Link Gateways or Data Center Experts to a site or a room
Click Settings > Gateways/Data Center Experts. Click Do you have more than one Gateway/Data Center Expert? Click here to connect.
Enter a name for the Gateway or DCE, and the code that was sent to your mobile phone.
In the main device list, check the devices you want to move to a site or room. Click Move to... and select the site or room you want to move them to.
Click Settings > Call priority. Add users to the call priority list for each site. Drag and drop to set the priority for how StruxureOn operators will contact users.
