Supplemental OIDs option
DCE configuration
  • EcoStruxure IT Help Center
  • DCE configuration
  • DCE configuration
  • Supplemental OIDs option
  • Mark as Read
  • How to manage NetBotz 250 rack access users in the...
  • Modbus Device Definition Files option
  • Mass Configuration of APC Network Management Card ...
  • Managing the device groups
  • Global Scan Settings option
  • Edit Thresholds display
  • Display for Configure Devices or Create a Template...
  • Device Scan Settings option for SNMP devices
  • Device Definition Files option
  • Device Configuration Status view
  • Data Center Expert Web Client
  • DCE server backup and restore
  • Configure Devices action
  • Assigning or moving devices to device groups
  • Device Launch Settings
  • Where can I download the latest version of Data Ce...
  • Removing devices from device groups
EcoStruxure IT Support
Request Support
Back to DCE configuration
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:15 AM
Use this option to add supplemental OIDs that define numeric sensors for monitored SNMP devices.
Once a supplemental OID has been added, the Data Center Expert server will request it for every SNMP device, with the supplemental OID value reported only by SNMP devices that can report the sensor associated with that OID. This allows the server to monitor and provide alert notifications for the supplemental OID the same way it does for any other sensor for SNMP devices.
You use the Other Numeric Sensors threshold option to configure alert threshold settings for an SNMP device that has the type of numeric sensor associated with the supplemental OID.
Note
To add a supplemental OID, you need access to the Management Information Base (MIB) that defines the OIDs available to the SNMP device.
Elements Description
OIDs Identifies the existing supplemental OIDs.
Sensor Type: The type of numeric sensor (temperature, humidity, air flow, etc.) that best matches the data reported by the OID.
Unit of Measure (only available when Generic is the Sensor Type😞 The appropriate unit or measurement (degrees, seconds, volts, etc.) used when reporting the sensor data.
OID: The definition of the OID to be monitored for an SNMP device (for example, .1.3.6.1.4.1.318.1.1.1.2.2.2).
Description: A description of the OID (for example, UPS Temperature).
Add Click to add a new supplemental OID.
Remove Click to delete a selected supplemental OID.
