Device Launch Settings
DCE configuration
  • EcoStruxure IT Help Center
  • DCE configuration
  • DCE configuration
  • Device Launch Settings
  • Mark as Read
  • How to manage NetBotz 250 rack access users in the...
  • Modbus Device Definition Files option
  • Mass Configuration of APC Network Management Card ...
  • Managing the device groups
  • Global Scan Settings option
  • Edit Thresholds display
  • Display for Configure Devices or Create a Template...
  • Device Scan Settings option for SNMP devices
  • Device Definition Files option
  • Device Configuration Status view
  • Data Center Expert Web Client
  • DCE server backup and restore
  • Configure Devices action
  • Assigning or moving devices to device groups
  • Where can I download the latest version of Data Ce...
  • Supplemental OIDs option
  • Removing devices from device groups
EcoStruxure IT Support
Request Support
Back to DCE configuration
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:14 AM
Last Updated: Sisko JLehr Sisko ‎2023-11-16 09:55 AM
Define how the server will use a web browser to communicate with the device or devices selected by Device Launch Settings, a right-click option in the Device and Map Views.
The Data Center Expert server uses these settings to connect to the web interface at any monitored device (Launch to Device, a right-click option in the Device View and Map view), and to connect to the Advanced View interface at any monitored NetBotz Appliance (Launch Advanced View, a right-click option in the Device View and Map view).
You specify the username and password used to automatically log in to the web interfaces of APC SNMP devices with the following Network Management Card and firmware revisions:
  • rPDU with Network Management Card firmware revision 3.7.1 and higher.
  • APC SNMP devices with a Network Management Card (AP9617, AP9618, or AP9619) with firmware revision 3.7.0 and higher.
  • APC SNMP devices with a Network Management Card (AP9630, AP9631, AP9635) with firmware revision 5.1.0 and higher.
Note: You cannot automatically login to the web interfaces of APC SNMP devices monitored by NetBotz Appliance versions 320, 420, and 500.
When Use the Internal Web Browser when Launching to Devices is selected in the Client Preferences option of the File menu, you can double-click the device, or select the right-click option Launch to Device, to automatically login to the web interface of devices that use basic authentication without being prompted for credentials.
  • HTTP: Select the HTTP protocol for browser communication.
  • HTTPS: Select the security-enhanced HTTPS protocol for browser communication.
  • Port: Specify the port used for browser communication at a selected device: 80 is the default for HTTP; 443 is the default for HTTPS.
  • Username: Specify the username used to login to the device.
  • Password: Specify the password used to login to the device.
Comments
jayrusek
jayrusek
Cadet
  • Mark as Read
‎2024-04-25 07:58 AM
How to you change the default launch settings that are applied when a device is discovered?
