Device Scan Settings option for SNMP devices
DCE configuration
  • EcoStruxure IT Help Center
  • DCE configuration
  • DCE configuration
  • Device Scan Settings option for SNMP devices
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to DCE configuration
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:14 AM
Last Updated: Sisko JLehr Sisko ‎2023-11-13 01:35 PM
Use this option to manage the settings the server uses for SNMPv1 and SNMPv3 communication with its monitored SNMP devices, as well as alarm settings the server associates with those devices.
The monitored SNMP devices are listed by Hostname (or IP address), and the following information is provided for each:
  • Device Type
  • Notification Policy : the notification policy the Data Center Expert server associates with alarms at an APC SNMP device.
  • Protocol: SNMPv1 or SNMPv3.
  • Port, Timeout, and Retries : SNMP communication settings.
  • Last Scan Time: date and time when the Data Center Expert server last scanned a device for status information.
You can edit the Notification Policy, Port, Timeout, and Retries settings, as well as settings not identified in the list. Select one or more of the listed devices and click Edit Device Scan Settings.
The following editable settings are not identified in the list:
  • Scan Interval (minutes)
  • Priority Scanning
    Priority Scanning is a trap-based polling process that only occurs in response to traps from APC SNMPv1 devices or informs from APC SNMPv3 devices where the Data Center Expert server is defined as a trap receiver.
    When an alarm occurs on the device, the device sends an SNMP trap to the DCE server. DCE receives the trap and then polls the device for alert information. Once the alert has been verified, DCE notifies users based on their notification policy.
    The trap receiver value is verified / set approximately every hour on APC SNMP devices.
    Note: Priority scanning is not available for third party devices; the specific communication required is not available in all systems.
  • SNMPv1: Read and Write Community names
  • SNMPv3: User, Authentication Protocol, Encryption Algorithm, and Authentication and Encryption Passwords
    If you select to edit SNMPv1 and SNMPv3 devices at the same time, no Priority Scanning, SNMPv1-specific, or SNMPv3-specific settings will appear in the "Edit Device Scan Settings" display.
