Global Scan Settings option
DCE configuration
  • EcoStruxure IT Help Center
  • DCE configuration
  • DCE configuration
  • Global Scan Settings option
  • Mark as Read
  • How to manage NetBotz 250 rack access users in the...
  • Modbus Device Definition Files option
  • Mass Configuration of APC Network Management Card ...
  • Managing the device groups
  • Edit Thresholds display
  • Display for Configure Devices or Create a Template...
  • Device Scan Settings option for SNMP devices
  • Device Definition Files option
  • Device Configuration Status view
  • Data Center Expert Web Client
  • DCE server backup and restore
  • Configure Devices action
  • Assigning or moving devices to device groups
  • Device Launch Settings
  • Where can I download the latest version of Data Ce...
  • Supplemental OIDs option
  • Removing devices from device groups
EcoStruxure IT Support
Request Support
Back to DCE configuration
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:14 AM
Last Updated: Sisko JLehr Sisko ‎2025-09-23 05:49 AM
Use this option to define the global scan settings the DCE server will use for communication with monitored SNMP or Modbus devices.
In both SNMP and Modbus Device Communication Settings > Global Scan Settings, the next device scan time is based on the Scan end time plus the Scan interval by default.
Data will be displayed in sensor history at intervals that equal the amount of time the scan takes plus the scan interval. This helps optimize network traffic, particularly when monitoring large numbers of devices.
To display data at the configured interval, select From scan start time.
Scan interval (minutes)
Select how much time will pass between DCE server scans for status information at a monitored SNMP or Modbus device when the Device Settings option in the Device Communication Settings display has Default selected for Scan Interval (minutes).
Note: Setting the scan interval below the default value of five minutes can adversely affect performance when the Data Center Expert server is managing a large number of devices.
Scan interval offset
Select whether the next device scan time is based on the Scan end time plus the Scan interval (the default) or at Scan start time (the configured Scan interval).
