Configure Devices action
DCE configuration
  • EcoStruxure IT Help Center
  • DCE configuration
  • DCE configuration
  • Configure Devices action
  • Mark as Read
  • How to manage NetBotz 250 rack access users in the...
  • Modbus Device Definition Files option
  • Mass Configuration of APC Network Management Card ...
  • Managing the device groups
  • Global Scan Settings option
  • Edit Thresholds display
  • Display for Configure Devices or Create a Template...
  • Device Scan Settings option for SNMP devices
  • Device Definition Files option
  • Device Configuration Status view
  • Data Center Expert Web Client
  • DCE server backup and restore
  • Assigning or moving devices to device groups
  • Device Launch Settings
  • Where can I download the latest version of Data Ce...
  • Supplemental OIDs option
  • Removing devices from device groups
EcoStruxure IT Support
Request Support
Back to DCE configuration
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:13 AM
Use a monitored APC SNMP device's settings to configure and apply those same settings at other monitored APC SNMP devices.
Note
You can use this action to configure the settings for a single APC SNMP device, by selecting it as both the source and destination device, and editing the settings you want to change at that device.
  1. Select Configure Devices and click Next.
  2. Use the "Select Configuration Source" display to select the APC SNMP device you want to use as the configuration source, and click Next.
  3. Use the "Select Destination Devices" display to select the APC SNMP devices you want to configure using settings from the selected source APC SNMP device, and click Next.
  4. Use the "Configure Device Settings" display to select, and edit, as needed, the source APC SNMP device settings to be used to configure the same settings at the APC SNMP devices selected in the "Select Destination Devices" display, and click Finish to initiate the configuration activity.
  5. Review the process of the configuration activity in the Configuration Status view.
