How to manage NetBotz 250 rack access users in the DCE SNMP Device Configuration option
DCE configuration
  • EcoStruxure IT Help Center
  • DCE configuration
  • DCE configuration
  • How to manage NetBotz 250 rack access users in the DCE SNMP Device Configuration option
  • Mark as Read
  • How to manage NetBotz 250 rack access users in the...
  • Modbus Device Definition Files option
  • Mass Configuration of APC Network Management Card ...
  • Managing the device groups
  • Global Scan Settings option
  • Edit Thresholds display
  • Display for Configure Devices or Create a Template...
  • Device Scan Settings option for SNMP devices
  • Device Definition Files option
  • Device Configuration Status view
  • Data Center Expert Web Client
  • DCE server backup and restore
  • Configure Devices action
  • Assigning or moving devices to device groups
  • Device Launch Settings
  • Where can I download the latest version of Data Ce...
  • Supplemental OIDs option
  • Removing devices from device groups
Data Center Expert
EcoStruxure IT Support
Request Support
Back to DCE configuration
  • Mark as Read
Lt. Commander ATrabert Lt. Commander
‎2025-08-18 12:08 PM
Last Updated: Sisko JLehr Sisko ‎2025-08-18 12:13 PM
Prerequisite
The Rack Access HID card and the user must already be registered with at least one NetBotz 250 appliance.
Detailed steps for using APC Device Configuration
Also see this FAQ
To manage and mass configure NetBotz 250 rack access users in Data Center Expert:
  1. Log into the DCE desktop client. Select one or more rack manager devices.
  2. Right click and then click APC SNMP Device Configuration.
  3. Use the default Standard device configuration settings and click OK.
  4. Use the default Configure Devices or one of the other three options. Click Next.
    The device you selected in step 1 is highlighted as the Configuration Source.
    • If it is, click Retrieve Device Settings to download the devices current config.ini file.
    • If it is not, or you want to use a different device as your configuration source, select it instead and click Retrieve Device Settings.
    • After it completes, click Next.
  5. Select one or more Destination Devices. If creating a template, this screen will be skipped.
  6. On the Configure Device Settings page, scroll to the bottom and expand Advanced Settings > RackAccessUser.
    The following Value information is displayed:
    • User State: Enabled, Disabled or Delete
    • Card ID: 123-45678
    • Which doors the user has access to: Door1, Door2, or BothDoors
    • Schedule: Day(HH:MM,HH,MM)
    • Name: FirstName LastName
    • Contact: FirstName LastName
  7.  Make any required changes using the syntax above or leave as is, and click Finish.
Review the Device Configuration status
If there were any errors, you will see Incomplete Configuration.
When deleting a user, the change goes through; Not Configured is the expected status since that is the returned result in the config.ini instead of the previously set “Delete,<CardID, <DoorAccess>,<Schedule>,<Name>,<Contact>
Labels (3)
  • mass configuration
  • NetBotz
  • rack access
