Display for Configure Devices or Create a Template actions
DCE configuration
  • EcoStruxure IT Help Center
  • DCE configuration
  • DCE configuration
  • Display for Configure Devices or Create a Template actions
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to DCE configuration
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:14 AM
Use this version of the "Select Configuration Source" display to select the APC SNMP device you want to use to configure other APC SNMP devices (Configure Devices action) or to create a template (Create a Template action).
Element Description
Filter Filter the table to list only entries that include the text you type, exactly as typed.
List Select the APC SNMP device you want to use to create the new template, or to configure other APC SNMP devices directly from its settings.
All APC SNMP devices monitored by the Data Center Expert server are listed.
Note
In addition to standard identification information (Hostname, Type, Model, Location, and IP Address), the list also identifies when the settings for a device were last retrieved by the Data Center Expert server (Last Retrieved column), if at all (Not Retrieved).
Device File Transfer Settings Click to access the "Device File Transfer Settings" display used to manage the File Transfer Protocol (FTP) or Secure Copy (SCP) access values for APC SNMPv1 and SNMPv3 devices.
Retrieve Device Settings Click to force the Data Center Expert server to retrieve the most recent settings for a selected device.
Note
You must retrieve the settings for a device that reports Not Retrieved as its Last Retrieved status before you can use that device.
Note
If a pop-up status message appears, you can click Status messages: Configuration Status view, a related information link provided below, for information about that message.
Next Click to access the "Select Destination Devices" display (Configure Devices action), or the "Configure Device Settings" display (Create a Template action).
Back Click to return to the "Select a Configuration Action" display.
