Edit Thresholds display
DCE configuration
  • EcoStruxure IT Help Center
  • DCE configuration
  • DCE configuration
  • Edit Thresholds display
  • Mark as Read
  • How to manage NetBotz 250 rack access users in the...
  • Modbus Device Definition Files option
  • Mass Configuration of APC Network Management Card ...
  • Managing the device groups
  • Global Scan Settings option
  • Display for Configure Devices or Create a Template...
  • Device Scan Settings option for SNMP devices
  • Device Definition Files option
  • Device Configuration Status view
  • Data Center Expert Web Client
  • DCE server backup and restore
  • Configure Devices action
  • Assigning or moving devices to device groups
  • Device Launch Settings
  • Where can I download the latest version of Data Ce...
  • Supplemental OIDs option
  • Removing devices from device groups
EcoStruxure IT Support
Request Support
Back to DCE configuration
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:12 AM
    Use this display to edit existing thresholds for the selected device.
    The display lists all the settings currently defined for each option.
    Element Description
    Threshold Types Select the threshold type you want to view in the display.
    Search
    Filter the list based on text you enter in this box; only existing thresholds that contain the text you type are listed. You can broaden or narrow your search using the Boolean operators AND, OR and NOT only.
    When the results of a search are displayed, the background of the search field is shaded. When you clear the search field, the background shading is removed and all items are displayed.
    List Check-mark the previously defined thresholds that you want to edit or delete.
    The following information is provided for the listed threshold.
    Threshold: the sensors that can be configured for the threshold selected.
    Current Value: the most recent value reported by the sensor.
    Parameters: the settings defined for the threshold.
    Alarmed State: whether the threshold is in an alarm state.
    Hostname: the hostname, or IP address when no hostname is defined.
    Unit of Measure: the unit of measure.
    Name: the name of the threshold.
    Severity: the severity of the threshold.
    Label : the device label, or IP address when no label is defined.
    Device Model : the model, when known.
    IP Address: The IP address of the device.
    Device Type: the type of device.
    Notification Policy: the policy or policies with which the threshold is associated.
    Edit Click to edit a selected threshold.
