Removing devices from device groups
DCE configuration
  • EcoStruxure IT Help Center
  • DCE configuration
  • DCE configuration
  • Removing devices from device groups
  • Mark as Read
  • How to manage NetBotz 250 rack access users in the...
  • Modbus Device Definition Files option
  • Mass Configuration of APC Network Management Card ...
  • Managing the device groups
  • Global Scan Settings option
  • Edit Thresholds display
  • Display for Configure Devices or Create a Template...
  • Device Scan Settings option for SNMP devices
  • Device Definition Files option
  • Device Configuration Status view
  • Data Center Expert Web Client
  • DCE server backup and restore
  • Configure Devices action
  • Assigning or moving devices to device groups
  • Device Launch Settings
  • Where can I download the latest version of Data Ce...
  • Supplemental OIDs option
EcoStruxure IT Support
Request Support
Back to DCE configuration
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:14 AM
You can remove devices from a group by dragging those devices from that group, or by using the Delete Devices right-click option in the Device View.
Note
Removing devices from a group does not delete them from Data Center Expert server.
Dragging devices out of device groups
When a device is assigned to multiple device groups, you will need to repeat this procedure for each device group.
  1. In the Device Groups view, select a device group to which the devices are currently assigned.
  2. In the Device View, highlight the devices you want to remove.
  3. Drag the devices to Unassigned in the Device Groups view.
    Note
    If you want to assign those devices to another group, you can drag them to that group instead of to Unassigned.
Using the right-click option in the Device View
  3. Right-click one of those devices, and highlight the Remove the device from group option.
  4. Select the name of the group from which you want the devices moved.
    Note
    The devices will be moved back to the Unassigned group.
