Rack airflow supports equipment
Provisioning match recommendations
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA: Capacity
  • Provisioning match recommendations
  • Rack airflow supports equipment
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to Provisioning match recommendations
  • Mark as Read
Picard EcoStruxureIT
‎2019-10-02 07:05 AM
This status message notifies you if there is sufficient cooling available for the selected equipment in the rack.
There is sufficient cooling available to support adding the selected equipment to the selected rack since all or nearly all of the rack's exhaust airflow will be captured.
There is sufficient cooling available to support adding the selected equipment to the selected rack but not all of the rack's exhaust airflow will be captured.
There is insufficient cooling available to support adding the selected equipment to the selected rack since too little of the rack's exhaust airflow will be captured.
See also
Enabling provisioning match recommendations
