Send InviteCancel
This status message notifies you if there is a match between any tags assigned to the rack and tags assigned to the selected equipment.
Tags assigned to the selected rack and equipment are consistent.
There is an inconsistency between the tags assigned to the selected rack and equipment. You may need to select another rack or piece of equipment, or change the assigned tags on either rack or equipment if these are incorrect.
There is an inconsistency between the tags assigned to the selected rack and equipment. You must select another rack or piece of equipment, or change the assigned tags on either rack or equipment if these are incorrect.
If you do not want matching tags to be a strict requirement, you can change this setting in the tag setup.
