PDU supports rack PDUs voltage
Provisioning match recommendations
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA: Capacity
  • Provisioning match recommendations
  • PDU supports rack PDUs voltage
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to Provisioning match recommendations
  • Mark as Read
Picard EcoStruxureIT
‎2019-10-02 07:05 AM
This status message notifies you if the connected PDU is capable of supplying the voltage needed by the rack PDU.
The defined output voltage of the connected PDU and rack PDU is supported.
The defined output voltage of the connected PDU and rack PDU is not supported. You may need to select another PDU or rack PDU for this power connection, or change the properties of either component if these are incorrect.
See also
Enabling provisioning match recommendations
