Rack PDU supports equipment's voltage
Provisioning match recommendations
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA: Capacity
  • Provisioning match recommendations
  • Rack PDU supports equipment's voltage
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to Provisioning match recommendations
  • Mark as Read
Picard EcoStruxureIT
‎2019-10-02 07:04 AM
This status message notifies you if the connected rack PDU is capable of supplying if the voltage needed by the equipment.
The rack PDU supports the voltage needed by the selected equipment.
The rack PDU does not support the voltage needed by the selected equipment. You may need to select another rack PDU or equipment, or change the voltage settings if these are incorrect.
See also
Enabling provisioning match recommendations
