Rack supports equipment's Watts per U-height
Provisioning match recommendations
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA: Capacity
  • Provisioning match recommendations
  • Rack supports equipment's Watts per U-height
  • Mark as Read
EcoStruxure IT Support
Request Support
Back to Provisioning match recommendations
  • Mark as Read
Picard EcoStruxureIT
‎2019-10-02 07:05 AM
This status message notifies you if you utilize the remaining power of the rack if you keep filling it up with more pieces of the selected equipment.
The rack supports continuing to fill up the rack with more pieces of the selected equipment as the sum of the estimated load per U-height will not leave unutilized capacity in the rack.
The rack does not support continuing to add more pieces of the selected equipment. You may need to select another rack or piece of equipment, or change the watt settings if these are incorrect, to keep within the physical boundaries of the rack.
See also
Enabling provisioning match recommendations
