Available copper-based network ports
Provisioning match recommendations
  • EcoStruxure IT Help Center
  • IT Advisor
  • ITA: Capacity
  • Provisioning match recommendations
  • Available copper-based network ports
  • Mark as Read
  • Rack tags support equipment tags
  • Rack supports weight of equipment
  • Rack supports equipment's redundancy
  • Rack supports equipment's plug type
  • Rack supports equipment's Watts per U-height
  • Rack airflow supports equipment
  • Rack PDU supports equipment's voltage
  • Rack PDU supports equipment's load
  • PDU supports rack PDUs voltage
  • Floor supports weight of equipment
  • Equipment fits into rack
  • Enabling provisioning match recommendations
  • Available fiber-based network ports
EcoStruxure IT Support
Request Support
Back to Provisioning match recommendations
  • Mark as Read
Picard EcoStruxureIT
‎2019-10-02 07:05 AM
This status message notifies you if there is a sufficient amount of copper-based network ports available for the selected equipment in the selected rack.
There is a sufficient amount of available copper ports to support the network requirements of the selected equipment.
There are available copper ports to support some of the network requirements of the selected equipment but the amount of available ports is insufficient.
There are no available copper ports to support the network requirements of the selected equipment.
Note: If you use the network type: other, the placement recommendations may not be reliable since the advisor does not support network port types that are not defined as either fiber or copper.
See also
